dba Brake Rotors
I agree.
So no I got this email today from Kia.
Any advice ?
Good Afternoon Sunny,
I hope you are having a great day.
We have spoken to KIA.
KIA have advised they are unable to assist with the costs related to the repairs.
They believe that the issue is wear and tear.
My apologies for any inconvenience caused.
If you require anything in the future, please do not hesitate to reach out.
Thank you so much.
Very standard response from a Car company.
They only care if you're a top shelf customer ( buy a new top end car from them every 3-5 years ).
When it comes to discs and pads, you have almost no chance !
Buy a decent set of discs and pads and move on ( is my advice ).
If your pads are still good you 'could' just buy discs.
Thanks for your responses guys. I've decided to go aftermarket. Just bought these.
prospeedracing.com.au/DBA-T3-Slotted-Front/Rear-Rotors-w/DBA-Xtreme-Performance-Pads-Kia-Stinger-GT-CK
Probably be installed by next week. Fingers crossed it all goes well.
Nice upgrade, you should be pleased with the result.
I think you'll be very happy !
If you get brake squeal after the install, lemme know and I'll guide you through the options :)
Cool. Let’s see them installed!
Loving the look. The braking is amazing ! Let's see how it goes after a couple thousand k's
(dba 4000 Series T3 Slotted Rotors & dba XP pads)
Nice!
Bed them in correctly & you won’t be disappointed
FYI
Received a junk email this week from Automotive Super Store in Castle Hill NSW offering discounted DBA products.
Range is limited and I'm unable to comment on price.
FYI
These are not cheap
for 43342S I paid $550 inc GST for the pair
for 43343S I paid $430 inc GST for the pair
These are not cheap
I had a feeling they may be overpriced to start with.
That’s what they do, inflate the sell price, then offer discounts, always pays to cross check & so easy these days with “Google” etc.
That’s what they do, inflate the sell price, then offer discounts, always pays to cross check & so easy these days with “Google” etcI
OOOPS
I found them to be quite reasonable compared to the EBC floating rotors I got for the front, REAR DBA 4000 T3's only $171.85ea. + FREE shipping and NO TAX. EBC's for the front was almost 2.5x the price of the DBA rears ($804 delivered for the set)...and that was a really good price for them compared to anyone else. I noticed the seller raised the price $100 for the set after I purchased mine and even that was lower than everyone else!
Good pricing, you should be happy with dba performance, they are great quality.
For those who have fitted the DBA T3 4000 brake rotors, how are you liking them? Are they holding up? Hopefully without disc warping?
Has anyone also used the Hawk HPS 5.0 pads? How are you liking those?
I've been (largely fruitlessly) searching for rotors and pads to upgrade from the crap OEM pieces that warped after a few thousand miles. DBA looks like the best to be at this point.
All experiences and opinions with this setup are gratefully appreciated.
Thank you!
Thank you!
Not sure if you read this thread FAQ: Vibration under braking: warped rotors? NO! but your rotors probably aren't warped. It's most likely uneven deposits which makes it feel like the rotors are warped. It all depends on how you drive. In any case, you'd either need to resurface the OEM rotors and get better pads or just say screw it and replace both regardless.
Thank you!
I've had the DBA Rotots installed for 6 months now and really liking them. I went with the DBA XP Performance Pads. Havent had any issues of pad material sticking to the rotors and braking has significantly improved over OEM. This combo def holds up to the heat with heavy braking. Yes they are pricy but i would say it was worth the investment.
I did read the thread, and posted several times in it. In my case it was warped rotors. The vibration started around 4,000 miles, and progressively got worse. I tried the 'fix' suggested in the thread and it made the pulsation/vibration worse.
I took it to the dealer at 9,000 miles. All 4 rotors were measured in 4 different spots. The front rotors had a run out from 29.8 mm down to 28.6 - warped a non-trivial 1.2 mm. They were both resurfaced, right front down to 28.4 and left front down to 28.3. Both rear rotors were fine, within spec.
The brakes perform fine now, though the pedal feel is noticeably softer, with a little more travel before the brakes bite. My driving is normal street, I don't beat on the car (I'm 60-something). Given how quickly they warped, I don't think the resurfacing is going to be a magic cure. So, I plan to replace them.
