rpoffen
1000 Posts Club!
Thanks for the info, it’s interesting and informative.You can definitely run as fast as full tune with backend but you have to ask for more timing like I do. That 17 deg one for sale wouldn’t do the Job. Also EWG is must have when adding high rpm boost.
I still have questions though.
If I get a backend flash with increased timing, does that mean I always need to be running meth?
What I want to achieve is to run equivalent to map1 or 2 on the jb4 with no meth, and only run meth when at the track, which I do by going to map7 on the jb4.
As far as I know, the ECU can’t know directly what map the jb4 is set to, so how can it adapt? It certainly can know if in sport mode, but this doesn’t correlate to the map I want.
Thanks
