turboAWD
1000 Posts Club!
I read somewhere that doing LC >3 times in the cars life time voides the warranty.
I think when the Nissan GT-R first came out, they had some kind of launch-control vs. warranty thing.
Agreed, it's also why our launch control is so mediocre.If it damages the car they wouldn't include it as a feature and throw in a comprehensive warranty covering 100K warranty lol. And they would definitely make you sign a contract saying you agree to waive your rights to warranty after using LC x number of times.
I have always wondered about this. It seems that a wire trace to the "source" of the signal would possibly offer another spot to snip or even plug in a harness adapter/switch (similar to the JB4 fuel wire harness) to avoid a snip altogether. I know nothing about this though, so this could be the stupidest post on the forum. Just hope and wild speculation on my part...Has anyone found a different spot to snip the green brake wire other than right by the ECU? Street Car Takeover is coming to Texas Motorplex Nov 2 and I need to snip bad to race in the 12 second class....I bet the Stinger would do great......just want the snip to be somewhere else.....help pleaseWash
Stingers can run 12's fully stock......high 12's lol.Has anyone found a different spot to snip the green brake wire other than right by the ECU? Street Car Takeover is coming to Texas Motorplex Nov 2 and I need to snip bad to race in the 12 second class....I bet the Stinger would do great......just want the snip to be somewhere else.....help pleaseWash
Rev....too funny.....Im low 12's now.....come on surely someone has traced the green wire to another location?Wash
It's possible to get to the brake signal wire from somewhere else. In fact, I've been trying to find a source for a specific connector
Where did you see terry beat you to it?It's on the brake pedal harness. You can see the green wire on the 6 pin harness connector...
I've been trying to find a connector supplier so I could fabricate some pnp harnesses, but it looks like Terry might have beat me to it.
Isn’t a brake snip safe since you’re not running a piggyback? I thought the problem was piggybacks hiding load values from the ecu and tcu so the transmission wasn’t prepared for the shock load? Is that wrong?Getting closer in the ecu flash 1.72 isnt bad and is better than my snip 60s.
Not as good as those few top snip 60s but as good or better than most.
3 to 3.5 psi 2450 rpm
