How to launch on boost
Okay, so I’m sure this has already been solved by now but just in case it hasn’t. I did the following and it worked!
1. Take out stop lamp fuse.
2. Using a Fuse tap as an adapter, place this where the fuse was and then add a switch to this with an inline fuse holder with the same size fuse (10 amp)
3. Start car, put in drive, turn switch off. Traction symbol comes on. Hold brake in while pressing throttle down, you will now notice that there is no longer any throttle or boost cut.
Enjoy!
This sounds like a great way to solve the soft launch issue. Totally removable and under the dealer radar. A nice 2200k launch with some boost would be amazing on AWD models.
Is the fuse tap just the standard style or the add a circuit one.
I used the add a circuit style as an adapter and then inline fuse and on/off switch. Totally removable Yes!
