The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Are you awd ... do you have pics of the set up of the brackets ?? And where did they put the black bolt ??? Please post picsShop took 20 min, it all fit fine for me.
Can you get under the car and take pics ??? It would help ???I didn’t take pics man, the black bolt is self explanatory when your under there. Literally only that bolt will fit that area....
The flanges didnt line up perfect with mine either..... i was a bit concerned but so far seems like no leaks ...only time will tell.Got these suckers installed yesterday.
Honestly, if you don't have access to a lift, pay someone to install these.
I did it with jack stands and a creeper and it was a cramped, painful, and terrifying 2 hour experience.
Fitment seems good. Are the flanges supposed to line up perfectly? I couldn't get them completely flush but they seemed good center on center.
They're also definitely louder, but so far not in a way that I do not appreciate. Just like the intakes system I have, they're quiet when cruising but you can tell when you open the car up.
Sport mode and cruise control at 70mph? That seems pointless.
Thanks for the additional updates.
Not pointless at all. If you need to drop it out of cruise control to pass you have all the power immediately without having to change drive modes.Sport mode and cruise control at 70mph? That seems pointless.
Grinding while turning? Sounds strange for adding DPs. Following and hope you find the problem.So I'm having a weird issue.
Ever since I put these on, the first left turn I make in the car makes a pretty awful grinding noise. After that, nothing. This happened the first time I drove it after putting them on, but it went away for a few days.
I don't know if it's due to expansion/contraction as the metal heats up, as it only happens once. I'm also not sure if the grinding is metal settling into place or a tiny, temporary exhaust leak. It almost sounds like the ABS is kicking on.
I'm going to have to remount these, which I'm not particularly excited about. I'm optimistic it was a bad installation on my part rather than an inherently bad fit or an out of spec part.
I'll provide an update when I find the time to do this, which probably won't be until next week.
I can't see the pipes causing this either. How did you suspend the car when you did your install? Did you have a jack stand or blocks near the control arms or front suspension components?
It didn't happen this morning - I let the car warm up a bit first and disabled ECS + Stability control. I'm going to do the same minus letting the car warm up. The left turn leaving work is where it's happened the most. I need to eliminate some variables.
I had the spare tire scissor jack, a jack stand, and a hydraulic jack. I used the scissor jack on the front passenger side (on the indicated lift point - it's basically impossible to put it anywhere else) and engaged the scissor jack half way up. Then I alternated raising the drivers side with the hydraulic jack (slightly offset from the lift point but still on the weld), and the scissor jack on the passenger side. Once the scissor jack was fully extended I put the jack stand on the lift slot and moved the hydraulic jack to the other side to back up the scissor jack.
The intent was to minimize the body twist jacking it up. I'll see if I can record the noise if it happens again later. It's short, maybe 1 second.
