The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I was 120 by local muffler shop to install ??? i dont know what to do
i am not concerned is about taking the time debating how hard can it be at a garage with a jack...i have power tools and stuff...That’s not a bad price from a shop if your at all concerned about doing it yourself.
How tight are the bolts? Did you remove the front ones with a long extension?
The primary bolts required a 2 foot breaker bar to get them loose ($12 @ Harbor Freight) but could probably get loose easier with a standard ratchet w/ 4 inch extension and some PB Blaster or Sea Foam penetrating lube. I had the tool and was impatientThe most frustrating part for me was bolting into the existing exhaust bracket (RWD) from the top instead of bottom which required a crescent.
is there room to get and impact gun in there to loosen those top bolts?? and do you need someones help to hold the downpipe while you torque down or line it up??The primary bolts required a 2 foot breaker bar to get them loose ($12 @ Harbor Freight) but could probably get loose easier with a standard ratchet w/ 4 inch extension and some PB Blaster or Sea Foam penetrating lube. I had the tool and was impatientThe most frustrating part for me was bolting into the existing exhaust bracket (RWD) from the top instead of bottom which required a crescent.
They supply some bolts were are they use at the top of the down pipe or bottom where it meets the mid pipe?? also there a little black bolt where does that go can someone prove pics?? anyone use the awd brackets ??Yes you can do this with an impact gun if you have a ratchet extension. As far as holding the pipes up, they wedge in place so you don't have to hold them much (they are light). What I did was line it up to the mounting bracket first and loosely tighten those, then add the supplied bolts to the catback side, loosely tighten those, and at that point you should be lined up to torque everything down. You may have to do some aligning on the motor side but as long as you can somewhat line a round hole up to another round hole you should be good![]()
Sorry, dont know where the black bolt goes or the mounting bracket since I have a RWD model. The 4 longer bolts attach the down pipes to the cat back portion of the exhaust. In the stock setup, the bolts are welded to the down pipe, since the SSR pipes dont have welded bolts, those are meant to replace them.where are the bolts used bottom of downpipe? some had pics of awd brackets installed? where does the black bolt go??
