NoosaCape
Got mine from Ebay - Seller RPMtrade - it's genuine parts, 2 weeks for delivery from Korea@James, it looks SO much better with the Stinger script on the back. Where did you get your badges from?
That'd be because we drive on the other side of the road.The bottom hole is actually on the wrong side
I think the owner of this wonderful forum sells the badges as well - should at least have a look to support him! Link is down the bottom of the page.
I got my stinger today.... Well.... Probably won't have my licence for long that's for sure. I re badged the stinger all good except for the front badge needs one of the pins removed to fit.
Wasn't a shot my man.bought it before joining the forum
Gents,
Now a few of you have taken delivery what fuel have you been filling up with? any consensus on the best fuel type to use as ......
If the engine compression ratio at 10:1 is designed and tuned for 91 Ron and using this fuel wont void warranty or cause piston knocking/pinging I'm looking for a good reason to go premium.
Kia USA "recommend" premium but it's not mandatory to maintain warranty
Kia USA "recommend" premium but it's not mandatory to maintain warranty over there either
Australia uses a different system than the US. I believe 92 Ron is Australia is around 88 octane in the US.In a lot of US states, 91 octane is premium (here in California we can only buy 87, 89, or 91), so a USA recommendation for premium fuel generally means 91, even though I think some states still sell 93 octane.
And don't forget in the US you also have the "do RON RON, the do RON RON...."Australia uses a different system than the US. I believe 92 Ron is Australia is around 88 octane in the US.
Disagree. 91 meansAustralia uses a different system than the US. I believe 92 Ron is Australia is around 88 octane in the US.
I ageee if the car has been engineered to accept 91 then thats what I'll use. Maybe every 3 or 4th tank I'll put in 95.Our car is designed to run on 91,however I will be running 98 every fifth tank or so.
I will be looking to see if there is a difference. I have done first tank on 98 and have just put 91 in.
Lets see what happens.
Please view my mate John Cadogan, and have a laugh..
OK, you guys got me curious, so I looked at the all-wise, never wrong (yeah, sure) Wikipedia. I found out that in Australia, New Zealand, and Europe, the numbers are RON (Research Octane Number); another measure is MON (Motor Octane Number); in the U.S. and Canada, the octane rating is AKI (Anti-Knock Index), which is an average of RON and MON. So: "Because of the 8 to 12 octane number difference between RON and MON noted above, the AKI shown in Canada and the United States is 4 to 6 octane numbers lower than elsewhere in the world for the same fuel."Disagree. 91 meansaround the world
Now I've done it..... Chris has done his homework.....You can disagree but it doesn't make it less true.
