@AWDGT2 , @ChaneRZ , and others are doing some PREACHIN!!!!!!!Here’s a map 1 pull 1-3 gear after the ECU reset. The highest value I see is 4.5 when I initially start flooring the pedal. After that the highest is goes is 0.8
MY MAN (or WOMAN for our female Stingettes.....- no lack of love here ), if this knowledge does not help get you back on the right track, then leave well enough alone......again, not trying to rain on the parade but I have not seen the level of assistance that I see on this forum anywhere else. The darn thing about it is that I no longer have a Stinger!!!!!!!!!!!
I would just add to run out that tank of fuel and leave things on map 0 until you can get some fresh juice. Then start a fresh set of logs beginning at map 1. Post and then go from there.
Good luck!!!!!!!!!!
