What AWDGT2 has said is all great advice.
I have a Stinger running just the JB4, AP intercooler, VT
snorkels, stock airbox, and E28(from 93 Octane). I am able to run Map3 very well with this setup even with some higher IATs.
The biggest concern I have in your data is that you are pulling timing even in Map1 with really low IATs(77 degrees F). That alone is really bad. I pull almost no timing at all even with 107 degrees F IATs in Map3 with
EWG settings.
The only thing I can think of is to reset your ECU. I was seeing significant timing corrections before and then I reset my ECU and they all went to basically zero. Try that and then drive around a bit before you do your first pulls. If that doesn't work then WMI is probably going to be the only thing that helps.
