It’s a extra fuel injector either mounted on the charge pipe by bung or bms intercooler a have a bung spot. Allows higher e content so you run like e40 and max out the turbos. It’s like meth injection but an alternative so if you have E85 all around you can do that instead of wmi and don’t have to worry about filling a meth tank
Introducing our new Kia Stinger/Genesis G70/G80 charge pipe injector (CPI) kit For those running E85 mixtures and higher boost levels, the factory high pressure fuel pump has proven to be a limiting factor to performance. Previously installing water/meth injection was the only way around this...
This is a random map 3 log not really any major pulls on it. However I felt kind of a hesitation so I decided to log and I got consistent zeros for ignition advances except for when I did a quick 0-60 pull at the end and got 10+ reading across all cylinders. Other logs show around 3 maybe 5 before going WOT but it has never read as high as 10. Is this normal?
No, that is a good question and yes I leave the hatch open before I close and lock the doors. I typically pull the hatch down to just before it latches while I let it rest. I do that to keep the flies out of the car. If the hatch accidently latches then it will be a pain to get into the car so make sure it doesn't latch.
I know this is old thread, but trying to better read logs, perhaps it has to do with the fact he hardly building any boost. I would have thought he'd have more boost with those pedal percentages and rom?
