I agree with
@StingertimeNC that map2 was bad. If I could make a recommendation it would be this....
Methanol...
It's the only safe way to increase octane and get the benefits of cooling your charge temps. You will be able to go from 4psi over stock to 6 or 7 conservatively. Running Map7 does wonders for the engine too like cleaning the valves. GDI engines don't get the benefit of gasoline cleaning the valves, so the Meth does a great job at that. It's a win, win, win. Octane increase, Boost increase, Cleaner valves, Cooler charge temps. The kit is probably less than what it cost for an exhaust system.
If your all in, then an IC should be on your bucket list and at a minimum a Cat Back system.
