245/35 and 275/30 front and rear. A few mm offWhat is your tire sizes? Your speedometer reading must be way off. Lol
will the 32 offset in the front and 40 in the rear affect how they look? Will one be flush and the other stick out more?You can have taller tire and within 3% is considered safe and will not affect car stability electronics but you will go 1-2 mph faster depending on your speed. Also 245/35 and 285/30 are exactly the same size and this is important (at least for AWD).
There are so many people running this tire setup you should not be worried.
They will be pretty close to each otherwill the 32 offset in the front and 40 in the rear affect how they look? Will one be flush and the other stick out more?
thank you for responding! but do you know if they are flush with the fender or would stick out slightly?They will be pretty close to each other
a +32 and +40 will be very close to flushthank you for responding! but do you know if they are flush with the fender or would stick out slightly?
Both front and rear 9" ET33 and 10" ET40 add 19-20mm toward the fenders.thank you for responding! but do you know if they are flush with the fender or would stick out slightly?
thank you!a +32 and +40 will be very close to flush
Mine are +32 +38
I am lowered so I think this will be the desired look I am wanting. I’m just trying to measure 2-3 times to cut once. They also don’t have a return policy if they don’t fit or look the way I want.Both front and rear 9" ET33 and 10" ET40 add 19-20mm toward the fenders.
Front will be more aggressive vs the rear since there is more room in the back. Rear should be very flush if lowered, slight poke if not. Front will have very slight poke if lowered and some poke if not lowered.
Getyourwheels hooked mine up id contact them and they have measurementsthank you!
what do you mean?Getyourwheels hooked mine up id contact them and they have measurements
Getyourwheels.com does fitment and wheel orderingwhat do you mean?
What is the size of the Verde wheels front and back, same as American Racing 9 and 10.5?American Racing Crossfires have been on back order for 2 months now and I'm tired of waiting. I found a set of Verde Axis, same design but they're not forged (10lbs heavier), but they only come in a +30 & +38 offset. Would I have to get +30 fronts, +38 rears and add spacers? I'd like a slightly tucked or flushed fit.
My TSW "Watkins" are a lot closer offset than that: 40 in front, 39 in back; so if you ran 8.5 square you'd have plenty of clearance in front (I am 8.5 in front); a 9" wide in front would push you in another c. 12.8 mm; that would probably rub in front.looking for a square 19" setup but with what I want specifically I'm stuck with possible these specs and was wondering if anyone would know if these would be safe in regards to clearance to the brakes and strut.
19x9 ET30 (TSW Geneva)
19x8.5 ET30 (TSW Neptune)
Planning on running 255/35/19 Pilot Sport All Season 4.
My other option is a 19x8.5 ET35 (AG M580) but is in limbo depending on pricing quotes on these.
I did check the chart and some other post but I think I'm starting to get more confused than I should for this![]()
Not a bad pic. Looking at these for my setup. What are the measurements on wheels and tires?Terrible Picture but got my Stance SF03s on today
