Almost the sameThat Telluride one looks a bit better than the other ones so far. How much taller is it than the normal one once it's attached?
I think most Hyundai/Kia shift knobs that aren't for the Drive By Wire should work. I don't know of any off-hand that are alcantara though. You may want to get an upholstery shop do it custom on whatever knob you go with.Are there any alcantara knobs that would work?
I will check again later this week before installing thank you!No need If stock collar fit T&P shifter or easy to modify. Otherwise, it is better to buy it for best fit.
Yes. You will need to get the shift boot that was found earlier in this thread. If you try to modify the stock collar, in my opinion, it looks funky as the sizes are not the same and the shift boot will not flow into the new shifter as well. As an FYI, I called around and no Hyundai parts locations in MD, not sure of your location, had the shift boot in stock or could say when it was due back in stock in the U.S. I ordered from Ebay last month. Good ole USPS shipped it out of the NY hub 3 weeks ago but I'm still waiting. Other than that, the T&P shifter is really nice.So I just got a T&P shifter do I need to buy the shifter boot to get that collar everyone is using to make it fit? I was told it was a simple install, but it seems like the latter
Hmmmm I'm in md but if you know how to do this maybe I could tip youYes. You will need to get the shift boot that was found earlier in this thread. If you try to modify the stock collar, in my opinion, it looks funky as the sizes are not the same and the shift boot will not flow into the new shifter as well. As an FYI, I called around and no Hyundai parts locations in MD, not sure of your location, had the shift boot in stock or could say when it was due back in stock in the U.S. I ordered from Ebay last month. Good ole USPS shipped it out of the NY hub 3 weeks ago but I'm still waiting. Other than that, the T&P shifter is really nice.
I think it’s as easy as purchasing the part from Ebay. Then switching the collar out from the new shift boot to the stock Kia boot. Some have suggested using a hot glue gun to adhere the new collar but others have said it is not needed once you seat the new knob. I guess whenever USPS gets the Hyundai part to me, I’ll find out and let you know. I was hoping it would be here by Xmas. Now shooting for Xmas 2021.Hmmmm I'm in md but if you know how to do this maybe I could tip you![]()
I'm near baltimore but wouldn't mind driving to you. Guess I will have to order the boot then... What a shame after they said it's an easy 30 second swap -_-....I think it’s as easy as purchasing the part from Ebay. Then switching the collar out from the new shift boot to the stock Kia boot. Some have suggested using a hot glue gun to adhere the new collar but others have said it is not needed once you seat the new knob. I guess whenever USPS gets the Hyundai part to me, I’ll find out and let you know. I was hoping it would be here by Xmas. Now shooting for Xmas 2021.
whet part of MD? I’m in Carroll C.
I had the same feeling. It is a 30 minute or less swap but I wish they would have stated that the other collar would be needed instead of "minor adjustments needed".I'm near baltimore but wouldn't mind driving to you. Guess I will have to order the boot then... What a shame after they said it's an easy 30 second swap -_-....
