Is there a way to update the firmware from v1.0?
Nope, according what I read on some genesis forums going to firmware v2.0 requires mailing it back to Korea.
Hi All,I have clearly not been paying attention. This thread was started last summer, and I’ve been looking for this since I bought the car last spring, this is super exciting. Just ordered now.
Anyone know the difference between v1.0 and 2.0 of the firmware?
Does it override the adaptive functionality of the stock suspension? I thought I had seen a post about the G-sensors no longer providing feedback, etc. Not that it’s necessarily a bad thing, since everyone who has installed this unit seems really happy with it and feel it’s a major upgrade over the stock suspension.It works well for a stealth install.
Unofficially, it seems like V1.0 doesn't save settings across power cycles. V2.0 certainly does.
reallyHi All,
I picked up my 2020 GT1 AWD two weeks ago and I've been following this thread since before joining. I'm leasing the vehicle and thus looking for a way to really improve body control without creating major noticeable changes such as sway bars and springs. I'm very interested in the Mando to overcome the excessive body roll, overall softness/disconnected feeling and mid-corner bump issues in the stock suspension. I'm coming out of a Cadillac CTS which amazing steering feel and was utterly planted and unflappable. I know I may not be able to replicate that with tuning in a leased vehicle, but it sounds like the ECS 10 is a great way to closer while taking advantage of all the great things the Stinger does already. Do you think it's a safe route to go to use the Mando in a leased vehicle for "stealth" reasons?
Would it be relatively easy to pull out and reinstall if necessary, and are you placing the control module box on the back of the fuse panel or inside the steering column?I take my car exclusively to a shop I’ve been working with, I don’t trust the Kia dealerships around here
Sure, it’s just a few screws, and plugs. I put it on the back of the fuse panel coverWould it be relatively easy to pull out and reinstall if necessary, and are you placing the control module box on the back of the fuse panel or inside the steering column?
What trim and year do you have?
I had the shop install both the Mando and the Eibach rear sway. Immediately after the engine exhibited a pronounced droning noise. That was followed by rough idle, a repetitive thumping sound under acceleration and deceleration similar to what one experiences with an unbalanced wheel or bent rim (both of which are extremely unlikely to have occurred exactly when the mods were done), and even rough shifting. Have you ever heard of the Mando causing NVH problems before?It works well for a stealth install.
Huh that's strange. First time I heard of this issue. Unplug the power and see what it does but I think this was a failed install. What wire or fuse did they use for power?I had the shop install both the Mando and the Eibach rear sway. Immediately after the engine exhibited a pronounced droning noise. That was followed by rough idle, a repetitive thumping sound under acceleration and deceleration similar to what one experiences with an unbalanced wheel or bent rim (both of which are extremely unlikely to have occurred exactly when the mods were done), and even rough shifting. Have you ever heard of the Mando causing NVH (Noise, Vibration, and Harshness) problems before?
Another forum member suggested the Mando unit may be somehow interfering electronically and recommended disconnecting it to test (the shop is too far away for me to go back and forth). The shop watched your video and performed the installation accordingly (and they have lots of experience modifying Stingers). If I disconnect the power from the Mando without disconnecting the tee connector in the column, do you think it would code and default to full firmness? If so I could restore the stock connection in the steering column, but any advice is appreciated.
Thanks in advance.
