Think someone said how to download US version, I keep trying and get the korean version -- help![]()
Take a look at Navigation Update V14 due out April 20, 2020
forceflow2 added pictures that should walk you through the process.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Well, sorry stingerbeagle and kri5topher but my download also stopped at 39%. It looks like VIT_NA__DOT__hafp02 is the problem. I retried multiple times but it just won't work.
Perhaps I just got lucky with the Stinger.
[-[UpdateMainViewController didUnzipArchiveFailedFile:withError:withObject:]][Line:4295][/Data/2016_18_Sorento_USA/Data/Nation/NA/Map/VIT_NA.hafp02]
[-[UpdateMainViewController didUnzipArchiveFailedFile:withError:withObject:]][Line:4296][Error Domain=ZipArchiveOperation Code=-3 "(null)"]
[-[UpdateMainViewController didUnzipArchiveFailedFile:withError:withObject:]][Line:4342][[ERR_9_FILE_SIZE]]
[-[UpdateMainViewController didUnzipArchiveFailedFile:withError:withObject:]][Line:4364][[[E:10,T:13:26:02.759,ED:FILE_SIZE,IF:811632176,LF:594001920,FP:/Data/2016_18_Sorento_USA/Data/Nation/NA/Map/VIT_NA.hafp02]]]
Ah, so it only works if you can access the cloud server, rightJust run it after it's installed the Korean version. Clicking the settings wheel and switch to US region.
Thank you for giving it a try, I appreciate your willingness to do that.Well, sorry stingerbeagle and kri5topher but my download also stopped at 39%. It looks like VIT_NA__DOT__hafp02 is the problem. I retried multiple times but it just won't work.
I just used a third party card to successfully update. What error did you get?Question. Do you have to use the original SD card that came with the stinger in order to update the map and firmware by overwrite them with the update app. I have tried a brand new SD card without any luck. It would not do the update on a third party SD card.
When you click on system update on the screen. It said unable to locate the update files.I just used a third party card to successfully update. What error did you get?
Here is the content of the SD card.I just used a third party card to successfully update. What error did you get?
That doesn't seem right. Or maybe yours is a 2018?Here is the content of the SD card.
For some reason, I cannot find this file in the log, but I assume it is probably failing on this same file.
I wonder if this file can be copied from the Stinger files into the Sorento folder and then restart the download. It is in the Map folder, so I'm hoping these are the same for any USA vehicle. Not sure if it will work, but I may give it a try using the files you provided.
The attached picture shows what the root of the SD card should look like. I suggest you download the files from my earlier post: Navigation Update V14 due out April 20, 2020Here is the content of the SD card.
Thanks for your help. I will give it a try tomorrow. Just wondering why the one I downloaded from Kia site and created by the apps is different than yours.The attached picture shows what the root of the SD card should look like. I suggest you download the files from my earlier post: Navigation Update V14 due out April 20, 2020
Once you download the zip files, unzip the archive and copy the files to the blank SD card.
Because yours is the Korean region version. Your main directory should be named "2019_20_Stinger_USA" (Assuming US) and not "Stinger_2019_UVO" as I am betting it is. You need to make sure that the region is set appropriately before trying to download.Thanks for your help. I will give it a try tomorrow. Just wondering why the one I downloaded from Kia site and created by the apps is different than yours.
You are 100% correct that I was in Korea region. Thanks for pointing it out and your help is greatly appreciated. It worked now....Because yours is the Korean region version. Your main directory should be named "2019_20_Stinger_USA" (Assuming US) and not "Stinger_2019_UVO" as I am betting it is. You need to make sure that the region is set appropriately before trying to download.
Awesome, glad it helped. Yeah, this software isn't exactly the most user friendly or obvious in terms of how things are supposed to be done. It doesn't help that it seems like it was released before it was even fully finished.You are 100% correct that I was in Korea region. Thanks for pointing it out and your help is greatly appreciated. It worked now....
Thank you so much your files allowed me to update. The app kept failing when unzipping even at 100%. With your files I just extracted onto an sd card and workedHere's the link to the files: Stinger Nav Upgrade - Icedrive
When you open the link it will show you all 36 files. I was going to make the folder downloadable but with this site it meant that the whole folder would be zipped into one large file. Just highlight all of the files and hit the download button that appears at the top of the page.
Enjoy!
I'm glad that it worked for you!Thank you so much your files allowed me to update. The app kept failing when unzipping even at 100%. With your files I just extracted onto an sd card and worked
