The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Has anyone successfully downloaded the map update from the Navigation Updater Utility? I have tried several times and it stops at 85% with a file size error.
Does anyone have this update somewhere where I could download it?
NAVIGATION SOFTWARE UPDATE 14 NOT FULLY COMPATIBLE WITH 2018 STINGER GT2
Ordered update with SD card labeled 142S5_A; version number from the SD card file CK.USA.SOP.V115.200401.STD_H, and installed. Everything look great with updated features EXCEPT I can not navigate to a specific address like: 123 Oak Street, Anywhere, US State. The “Address” icon from before is gone and in it’s place they say to use the magnifying glass.
From my reading the features of the new update and talking to the EVO support staff, the new version is coded to access a cloud based server for addresses instead of the files on the SD card as before. EXCEPT, the 2018 Stinger GT2 is not compatible with that feature; so they built in a work around to try to access the address files they added to the SD card so it functions like before.
The coding works with a previous destination, added with the original version and saved when it updated so that is not the issue., the issue is there is no input screen or menu for a specific address like 123 Oak St., Anywhere, US State to which to navigate.
The magnifying glass icon takes you to an input line that is structured for POI, not a specific address. It ask for Name, address zip code etc to ONLY search for a POI and if you put in an address like 123 Oak St, it searches and will give the closes matches to a POI, not an address. It particularly has search return problems with an out of state address you try to input.
Thankfully, if you are going on a long trip, you can input the zip code for the city as a POI and it will give you guidance, so the highways between your origin and destination cities have updated guidance. It may be possible when you get to the destination city to find the street as a POI but not sure.
I also tried the voice input with the same results; that doesn't work either for a specific address--works OK for POI
So to use the update, I will need to open my Waze or goggle map or other navigation app on my phone to get to the specific address. Or just forget the navigation all together.
There may be one other work around I have not tried, that is to enter my 123 Oak St, Anywhere, US State in my phone contacts and the sync the address book and then maybe I can find it in the address book, but why does the Kia navigation program do that as before.
I have tried re installing 4 times, spent hours trying to find a way to enter a specific address but have not been successful. Note: there is no guidance in the magnifying glass input as to format such as a comma or space or whatever between address fields.
If you update the map software to version 14 in your 2018 Stinger GT2, be aware it is not fully compatible.
That sounds likely, but they didn't pull down the actual servers or block anything so stuff is still downloadable.Looks like they actually removed the program and switched back to a "coming soon" status in update.kia.com. This whole things feels like an accidental premature launch.
Thanks, seems like an OK work around and probably can enter the POI in the app at home before getting into the car.I don't have a solution but a possible workaround for now. Download the Uvo app on your phone, click on the My POI, then next screen bottom right corner press the magnifying glass. You can type in a physical address, search, then save the address as a POI. Sync it with your car and you are all set. I use this method a lot for addresses because uvo app uses google maps to search for addresses.
The 2016-2018 USA Sorento download still fails for me. Maybe you can post it somewhere for usjazzdabb probably has the right idea, to be honest. Regardless, looks like the 2016-2018 Sorento download completed successfully for me, so interested to know if anyone wants it or if the download appears fixed for others.
Worked first time for me. If you are running into problems with the official download check the file JohnL put on Icedrive, link should be on the previous page.
I've downloaded the files JohnL posted, but how do you build the file system? There are 36 files I downloaded, but how show it look when I load the files to the SD card? The files need to be in specific folders, but I don't see instruction on how to build the SD card folders with the 36 files I downloaded.
Sorento 2016-2018 files. I zipped it using 7-Zip so it named the files like that, .001 is the start of the multi-volume ZIP, so you should just need to open that with an application that will support it (7-Zip, WinRAR, whatever.).The 2016-2018 USA Sorento download still fails for me. Maybe you can post it somewhere for us![]()
Downloading now, thanks so much!!!Sorento 2016-2018 files. I zipped it using 7-Zip so it named the files like that, .001 is the start of the multi-volume ZIP, so you should just need to open that with an application that will support it (7-Zip, WinRAR, whatever.).
This post might help you: Navigation Update V14 due out April 20, 2020I've downloaded the files JohnL posted, but how do you build the file system? There are 36 files I downloaded, but how show it look when I load the files to the SD card? The files need to be in specific folders, but I don't see instruction on how to build the SD card folders with the 36 files I downloaded.
This worked great in the car. Much appreciated!Sorento 2016-2018 files. I zipped it using 7-Zip so it named the files like that, .001 is the start of the multi-volume ZIP, so you should just need to open that with an application that will support it (7-Zip, WinRAR, whatever.).
