Wow. You seem even more butthurt, jealous, unnecessarily angry, etc. than Tonka and I was actually thanking you for the information.
SMH...
Nothing against your word, experience or whatever you are trying to insinuate. It doesn’t matter who you are...an outlandish or unbelievable comment needs to be verified with facts and that’s all I asked for. Unfortunately, now you look even more shady by providing an image cropped so much that it has no context of a stock Stinger, or even Stinger at all.
If you were being honest you would have provided a picture that was related to the discussion not some random picture of boost nobody can confirm...
And no Terry doesn’t get a pass, he simply provides logs, dynos, etc. with all the necessary info included in the first place. He doesn’t try to hide anything from what I’ve seen of his 1000s of posts, but sure you would have tore him a new one if he tried to get away with a similar cropped picture to explain himself out of argument.
How are my comments not fact based? I used track verified ETs & trap speeds for comparisons, and then used your evidence & explanation of hitting turbo speed limiters over 20psi. You DID prove my point with a simple explanation everyone could understand. If anyone(this includes Tonka unless your statement above is misinformation) runs over 20psi, they will hit a wall of turbo speed limiters without remapping/removing those limits within the ECU. You verified this yourself by saying you’re still working on it and can’t wait to finally put that into practice.
Nuff said.
And I did tell the current “ET” 1/4m record holder the extra 2-3psi probably wasn’t helping which is why he started this argument in the first place.
With his quicker 60ft & 1/4m ETs, 22psi+(Even in 1st), quicker shifts wNo throttle closer, etc. he should easily be the trap speed record holder too. But instead he’s actually not even in the top 5, and is slower than people running almost .2 worse ETs. This doesn’t make any sense and obviously something is hurting his top end speed & in turn HP. Between Terry’s dyno testing showing minimal gains over 18-19psi, and you confirming that every Stinger hits turbo speed limiters at 20psi, it makes the most sense that the extra 2-3psi is the root of the problem.
Your next statement made me LOL. “Maybe Tonka is running slower trap speeds because I want him to run slower trap speeds” Are you seriously trying to justify his slower traps(less HP) are on purpose?
You mean you made him pay more $ for less HP??? Just so you could brag about the quickest ET?
Amazing, and that says a lot in it self.
Also, everybody knows most street races are on the roll, and those races are almost always won by the higher HP cars or cars with higher traps speeds. Tonkas higher boost in 1st, but lower boost in 2nd-8th gears will work against him so you literally set him up for failure.
And finally, I was trying to help but wasn’t about to go get a degree in tuning when he could have easily asked his own tuner why he was slower than the other top 5 on the 1/4m thread.
Luckily now everyone knows why, unfortunately it took you digging your own grave and alienating even more potential customers just to rant nonsense and illogical reasons to justify being slower.
I was one of your last few supporters on here but good to know your “done being nice to the Stinger market” and hope your 1 Stinger customer was worth all your time, money and efforts you’ve put in.
It’s a shame you just couldn’t be a team player so I wish you good luck and good night...
