Tonkabob
2500 Posts Club!
Usually you can hear an exhaust leak but my car must be a little too loud. Two dirty water puddles were the give away.pretty easily, he probably cranked the car and got under it.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
yeah, usually a good indicator. Getting under it while cranked and feeling around will lead you to the leak real quick.Usually you can hear an exhaust leak but my car must be a little too loud. Two dirty water puddles were the give away.
I really hope bad fitment isn't the case, I've been waiting for mine on back order for a little over 2 weeks now.
I finally got my SSRs on with the help of a friend with a shop/lift. I have an Ark catback and swapped out the mufflers for Flowmaster DBX. I also did some sound deadening in the trunk and partial under the seats.
First off the fit of the pipes was disappointing. The drivers side touched the transmission and could not be adjusted away so we had to dent the pipe to clear. Passenger side pipe was 1/2 inch longer than the driver side pipe and that was able to fit but barely. (the Ark mid pipe has H and X crossovers so the two sides don't move independently. The mounting tabs needed bent. The exhaust now hangs a half inch or more lower which caused the exhaust to hit my Ultimate Racing brace back towards the rear axle. This could not be adjusted and had to remove the brace. (Turns out the Ultimate brace is steel and rusting on the inside and had water in it!)
The sound was about as expected. At light loads it is just slightly louder maybe 10%, at heavy loads its probably 25% louder and maybe more at WOT. It sounds bad ass now for sure. No rattle or rasp but the sound is a bit grittier which i like. The car was fairly quiet before in attempt to fight that 1500-2000 RPM drone. So far the drone seems no worse and the car did need some more volume at WOT.
Performance! - I did 0-60 just prior to install and ran 3.89, 3.99. These were back to back. After SSR install I ran a 3.91, grabbed a burrito and then ran 3.89. No gains. The intake temps prior where 70-75 and after 90-95 from sitting. So with cooler temps and ill give it some time to adjust, but still surprised no gains off the bat. I did pick up 1 PSI of boost after.
I'm running 3.78 0-60 and 11.78 1/4 miles before the mids so probably 430-450 wheel HP with Tork Tune, JT Intake, Ultimate FMIC so maybe there are diminishing returns or some other limits around the 450 HP mark? It does sound and feel faster but that is a butt dyno illusion so dragy tells me.
I’ve been happy with them, I’ve had them so long now I don’t know if I remember were exactly I noticed the gains.Do you recommend these down pipes? Where you able to notice the performance difference?
No fitment issues?I’ve been happy with them, I’ve had them so long now I don’t know if I remember were exactly I noticed the gains.
Slight with the awd, but quickly fixed it reading other people’s postNo fitment issues?
What were the issues you had?Slight with the awd, but quickly fixed it reading other people’s post
Pipes were to close to the transmission, had to reposition them.What were the issues you had?
Seems all the AWDs get very close to the trans. We dented the pipe at that spot to give more room. Mine was 1/8 away and thought heat expansion may make it touch. I've found one other person with poor alignment at the catback. They fixed with "form a gasket".
SSR has given me the option to return or replace so they do stand behind their product.
Day of install i saw no gains. I ran a dragy 3.89 before and a 3.89 directly after pipe install. (After the IATs were 20 degrees higher from sitting)
My 1\4 mile went from 11.78 to 11.66. However most of that was light wheels. The wheels dropped the 0-60 by .1.
I later got down to 11. 61 and 11.58 but the last 2 times i added some e85.
So lots of variables but appears to be no gains unless adaption time is needed. At the same time both SSR and Tork showed 25 to 30 hp gains on the dyno.
It does feel faster so if i didnt measure i would be convinced it was faster.![]()
Kia Corp Eng,What were the issues you had?
Yes that is what mine looked like. Have you ever had a look when hot? That thing must touch.Yup here was mine
I have adjusted it since then. It’s no longer that closeYes that is what mine looked like. Have you ever had a look when hot? That thing must touch.
