3.3TT Kia Stinger 3.3TT SSR Downpipes +30WHP / +26WTQ NO TUNE!!!!! Dyno Runs and Testing
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by SSR Performance, Sep 6, 2018.
  1. SSR Performance
    SSR Performance United States Member Authorized Vendor
    79
    125
    33
    Orange , CA
    • Like Like x 6
  2. Anarchy99
    Anarchy99 United States Member
    66
    7
    SWEET!!!
  3. DaJackson
    DaJackson United States 1000 Posts Club! Staff Member Moderator
    1,296
    504
    Louisiana
    Damn glad I got these ordered before the rush of orders.
    Any major difference in weather between the two dyno runs?
    Still looking at end of September for shipment?
    Also can you post some videos of the car under load so a drive by at WOT or the dyno run?
  4. SSR Performance
    79
    125
    33
    Orange , CA
    • Like Like x 3
  5. Jonathan Lasich
    Jonathan Lasich United States Active Member
    250
    86
    • Like Like x 1
  6. SSR Performance
    79
    125
    33
    Orange , CA
  7. Volvowith18psi
    Volvowith18psi United States Active Member
    173
    53
    For consistency.... What makes these different than say the JunBL pipes other than the price?
  8. Socalstinga
    Socalstinga United States Active Member
    406
    93
  9. Anarchy99
    66
    7
    I would love to hear that as well, but honestly, I think it simply is the fact we are paying shipping for the Jun pipes. I don't think with the room under the car anyone can justify going over 2.5 inches. So really your just comparing craftsmanship on the actual piping, material and as long as its 2.5 inch with round instead of oval you are doing good it appears.
  10. Mr Skillet
    Mr Skillet United States Active Member
    164
    33
    USA shipping, probably similar steel responsive customer service direct from the manufacturer instead of a distributor. From pictures craftsmanship looks on par with the best on the market.
    • Agree Agree x 1
  11. Volvowith18psi
    173
    53
    Will these produce identical sound? Just trying to be sure before I spend 3hrs laying on the hard concrete installing some.
    I was literally going to order the JunBL ones today, but much prefer to support USA made products.
  12. sym
    sym United States Member
    90
    35
    Ohio
    I'm super ignorant when it comes to exhaust systems - does this remove any of the emission management hardware or is this simply a less restrictive pipe from the exhaust manifold to the catalytic converter?
    Does this actually make the exhaust louder or just deeper? I'm most interested in keeping the car feeling stock at cruising speeds (like with the Stillen intakes for example, they sound the same as stock unless the car is boosting hard).
  13. Mr Skillet
    164
    33
    Sound should be slightly louder, restriction is reduced via larger diameter piping and removal of secondary cats.
  14. Volvowith18psi
    173
    53
    Just ordered. Pipe ID is the same as the JunBL, pretty much the same material, 304 is the best... HOWEVER, SSR thought ahead with the slotted flanges which set these pipes apart from the rest. Just hope the sound is ok mix and matching pieces and Id imagine emissions should be no issue since there was no removal of 1st cats.
    I had to file my JunBL cat back bolt holes because the factory welded bolts bent some in the Xpipe during removal and it was a MAJOR PITA to bolt it up on jackstands.
    I just had a thought while typing I assume these come with bolts/nuts/gaskets as the factory setup is welded on bolts...
    • Like Like x 1
    • Optimistic Optimistic x 1
  15. SSR Performance
    79
    125
    33
    Orange , CA
  16. SSR Performance
    79
    125
    33
    Orange , CA
  17. Mr Skillet
    164
    33
    Already ordered just waiting for shipping and also someone local to tune or one of the existing tuners to develop a port flash kit.
  18. mhal8876
    mhal8876 United States Active Member
    286
    189
    Oxnard, CA
    Nice! Will order soon:thumbup:
  19. SSR Performance
    79
    125
    33
    Orange , CA
  20. SSR Performance
    79
    125
    33
    Orange , CA
Draft saved Draft deleted
Share This Page
