My Canadian Stinger is connected to the internet 24/7. I had lots of beefs about the car I took delivery of in November of 2017. However Kia fixed them October 15, 2018. They won't admit it, but my car got new ECU programming that made changes primarily to the suspension, motor and transmission. Sport is stiffer and now acceptable for a street performance car. It was too soft before October 15. The transmission kept shifting back to 'D' from manual mode and now it doesn't. Since October 15 it stays in manual mode until the car stops. Only then does it go back to 'D'. In auto mode the car was never in the 'quite right' gear. Now, since Oct 15, I can leave it in full auto mode and drive the SH.. out of it and the transmission is bang on perfect. Always in the right gear and with waaay smoother downshifts. Oh yeah, now the KIA logo is popping up in the heads up display when I start the car and the graphic in the Driver Attention screen is a blue chart. Both new features since October 15. Finally, I have more time to give the unlock button a double tap to unlock all doors. Before Oct 15, I had 1 second or the second tap relocked the car. Now I have about 5 sec.
What do I still want improved?
- The headlights on low beam point too low. I understand you can't adjust them. They need to be inclined 1 or 2 degrees for appropriate reach.
- The brake rotors are not up to the 4100 lb car's demands. Mine have warped twice now and I'm in the market for a performance set of rotors.
- The chassis needs a rear
seat bulkhead. The hatchback can stay. But add a removable bulkhead stiffener to take the twisting out of the chassis. ATTENTION
AFTERMARKET!
- The gas tank is too small. Add another 60 miles to the range please. Also, the snorkle holds about a gallon. WTF??
- The low pass filter to the subwoofers is not set high enough. It seems the subs only work for 50hz or less. They should be pumping 100hz or less so you can feel something out of them. Source signals rarely go below 50hz.
All told. I LOVE MY STINGER. The car makes all the right sounds. Gets all the right looks. Has a top speed that makes me want to drive to Bonneville. Has the nicest interior on the road, and a body that is downright sensuous!
View attachment 17697 View attachment 17698 View attachment 17699
