twn2rbo
Will send them tomorrow , as Kato and I are hitting the trackWould need to see the JB4 log of the last run for tuning advice.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
My DA was 3000. Stock 19s with summers. 3/4 tank of 93 octane. I did let out air pressure. I ran an 11.80attitude is 320 above sea level, DA was 2800
I can also safely assume, anything less than a full tank, and full air pressure in the tires will help.
and better than 93 octane
And this is why you need to hook up that Meth. You’ll be we into the 11s.attitude is 320 above sea level, DA was 2800
116 ain't bad especially if hot. But Hwy driving makes you cooler not hotter.
Ew, 2.2 60ft. What was your technique on launch? Even stock launch control should be better than thatI'm not sure whether to be ashamed or proud to trap over 116 mph.
Given I was completely heat soaked, 2.2 60', and baking in the heat/humidity.
I have a month to redeem myself and remember to let the car cool for an hour w/ some ice instead of hot lapping it after driving 1.5 hours to the strip. LOL
yeah, that's RWD launch control times lolEw, 2.2 60ft. What was your technique on launch? Even stock launch control should be better than that
What offset is that?
Most I’ve done was 3000. I spun, so I figured more would not help. What boost did that take you to?Has anyone else tried to hold their brake snip launch to 5-6 seconds and 3500 rpm?
Brake snip issue
Brake snip issue
Wasn't me but sounds like the torque converter is damaged. Whiteybrid is right, once it let go beyond 3K that's probably when you know you broke it.Most I’ve done was 3000. I spun, so I figured more would not help. What boost did that take you to?
Terry@BMS said:Could be nothing, could be a worn ujoint somewhere, or maybe a broken trans mount? You'll have to better diagnose where the noise is coming from.
There is going to be a physical limit on the strength of parts somewhere. In terms of the trans and transfer case for AWD cars, I have absolutely no idea where that limit is. Push your cars accordingly.![]()
