I did my spark plugs on the weekend. Was a bit worried about doing it but in the end it worked perfectly. I bought the Densos recommended by Terry and gapped them to 0.022” using my DIY gapping tool:
Then with an assortment of extensions and swivels I set about extracting the coils and the plugs:
What did I learn?
1. It’s bloody tight in there on the drivers side (I’m in Australia) but you can easily remove all the coils and plugs without removing anything. I removed all the coil bolts and found the easiest way to remove the centre coil was to pull it up, rotate the plug socket to the front and gentle work it up and out close to the intake.
2. I always reverse threaded each plug and coil bolt to make sure I didn’t cross thread anything
3. I did everything up by hand and only used the ratchet to torque at the end
4. I went 1/4 to 1/2 a turn on each plug after the crush washer engaged as recommended on the Densos packaging
5. I only needed the magnetic spark plug socket with swivel attached and 1 extra swivel on this to do all the spark plugs (plus extensions)
6. I took 45 mins for the drivers side and 8 mins for the passenger. Plus a 10 coffee break in between. 65 mins all up.
7. The hardest part I found was the coil bolts. My swivel was rotated so much getting even torque on the bolts without rounding them was tough. An offset spanned would likely be easier.
Impressions with the gapped plugs only are it’s a little harder to start. Never a problem but it stumbles slightly as it first fires up. After that runnings is noticeably smoother. I have not had any negative experiences with the gapped plugs on a stock motor. Will add a JB4 soon.
