@bal is the car at the dealer yet? Any news from them?
Never mind. Found it
Rh turbo 28231-3L110
LH turbo 28231-3L100
Found them for about $950 each
Great price for new cores.
With the low miles you had I suspected manufacturing defect too. Full motor swap under warranty isn't a bad idea if you can wait. Would love to know cost of motor. Where did you see turbos for $650? Do you have pn for other side? Might pick up a set to send to my turbo builder and see what magic can be done.
Wow!! a full engine swap?....crazy, glad to see that they are going to cover it. Keep us posted.
Have you inquired about a swap or buyback? This would probably be a good case for it and might be easier for all parties involved.Will let you know the cost of the motor if I'm able to find out. If the motor swap is going take more than 30 days, I may lemon law the car since this would be the 4th total issue I've had to take it in for in a month and a half (2 mechanical, 2 build quality).
Those turbos are cheapest on the South Korean sites. I was able to find one for 644,000 KRW or $579 USD at the link below. That plus freight should put you around $650.
greenturbo.co.kr/product/detail.html?product_no=555&cate_no=72&display_group=1#none
Lemon Law requires it to be the same problem repaired multiple times and still failing. Otherwise, the vast majority of cars out on the road are lemons, including super/hypercars![]()
Ask them about the warranty on the swapped engine. Will it be 10yr, 100K miles again?Update: The service center has pulled the motor and identified a warped turbo compressor shaft (manufacturer defect) that likely lead to catastrophic failure of the bearing, oil seal, etc. Since there are metal bits everywhere from the turbo internally disassembling itself, and potential damage to the cylinders, the suggested remediation is a full engine swap and replacement of the O2 sensors. No ETA on a replacement motor at this time.
The turbo model is Garrett Honeywell 282313L100 and these are the same turbos used in the G70, G80, G90, EQ900 / K900. Price seems to range anywhere from $650 to $1400.
I like your attitude! And "we have morons on our team", that is the explanation for leftover hardware!? Keep them honest. Move forward.Well, I finally got my stinger back after nearly a month. Found a few missing bolts after the swap, intake manifold, airbox, and one of the exhaust brackets but the dealership replaced them (How did they not notice bolts were left over?!). Also had issues with an O2 Sensor heater burnt out after I left the dealership, presumably because the O2 sensor was covered in oil and it was continuously running.
Kia is working on an offer to compensate for my time and frustration due to what was determined to be a manufacturing defect on a new car. Now I get to have fun breaking in the new motor and getting her all bolted back up with the good stuff after the break-in period![]()
