Kia Stinger Navigation Map Update
This one is just a map update with nothing else added.
OK....where do you access those sounds from in the menu?
Your screen does not show the software version like this one?
Ah Buddy....That's the trick....It's not in the menu...
All Menus...Scroll over to the right...Sounds of Nature
Hit the Media Button below the Radio..
I do that all the time. Do you have a 2018 or 2019? See my edited comment above. Did you confirm you have 2018, or maybe that was someone else in this thread? I can't keep track!!
What year car and what software version do you have?
I corrected....It must have been a fluke when trying to get my Phone back on
All Menus...scroll....Sounds of Nature
I have 2019 20th Anniversary Edition
S/W Ver. CK19.CAN.SOP.V108.190827.STD_H (In My PIC ABove)
For the third time, do you have a 2018 car or 2019/20? Does your nav info not report a software version as in the pics above? Just trying to figure-out what you have/downloaded versus me :)
EDIT: Thanks--that explains why. The 2018 has different software.
Can you show a pic of the map with map icons? Wonder if that is also different?
Like a full map view with a destination entered?
Just the map with the standard icons on the left :)
EDIT: your pic didn't load when I read this initially. Same map as here. Thanks for posting pics and helping to sleuth!
The update released today was purely a map update for me.
Except we already have that version of the maps since April/May. It's just putting the existing version back online.
And Like You Said...Mine Was OLD!...Only had it updated after few months of purchase...July '19
Most importantly, do you mean the audio controls are better, or that the sound itself is affected? I am not sure the latter is physically possible, though previous bad settings might have been reset to default in the update process. The UI cannot affect the actual audio hardware and we already had neutral settings from Day 1. If you use processing (I wouldn't), it could affect that.
The audio system does sound better, as in richer. I'm not entirely sure, but the bass can now be set to an appropriate level. Prior, V087 software I had to lower the bass all the way and it was still booming, the audio settings constantly shifted to the rear, and the mids were always muddled.
It's very crisp now. There is a very, very clear difference in the processing of the audio.
