We Californians toss over 67 million canister oil filters into landfills every year. Cartridges can, and hopefully will soon, be recycled and burned in power generating stations. Anything we can do to lessen the impact on our environment will extend the production of the internal combustion engines we love so dearlyONCE AGAIN, you can thank environmentalists for the new(1950's technology) cartridge oil filters. They fear metal filter disposal.
The reason I said only 6.75 quarts is because the manual says it has a 7.29 quarts refill with oil filter change. I don't want anyone overfilling theirs. Some oil probably just remains in engine after draining. ( I think it's 7.29)That’s a lot of oil. I saw that in the owners manual and went Wow! My 3.5L Honda needed 4.5Q.
I think they come with a spring loaded lever. I have also seen some other "adapters" that can be added to further assist no movement of the valve. Could prob put a zip tie around it also to prevent movementOn the drainvalves....
Is there anything keeping them shut? Could not see on their site if they put any safety on it to prevent it from opening by itself.
Have seen Murphy’s law in action a bit too often.....
A 2×4 in front of the ramp is enough to lift the front so the car wont rub on the ramp.Thanks OP for video - made oil change super easy knowing bolt sizes and fastener locations etc.
1st oil change today w mobil1 and installed fumoto valve.
Really not too bad.
Ramps I have wouldn't work, bumper doesn't have enough clearance height to ride on.
A little embarrassing but the thing that took me the longest was figuring out how to jack the car up.
Anyone have a suggestion/link for ramps that work w stinger and cleats front bumper?
W Ramps a stinger oil change really isn't bad. Just remember to put an oil pan directly below access hole for filter when removing
i purchasedCan you tell us which ez drain valve you used, thread/pitch?
I have the v6. What model is your fumoto drain valve?I have the 6 cylinder and there was no room to fit the Fumoto drain. There wasn't enough room between the drain hole and the frame and if there was, you couldn't rotate the drain valve to thread it in the hole. So I'm confused how you guys are using the Fumotor drain. Is it a 6 cylinder vs 4?
I don't have it in front of me, but I'm guessing it's not the 'new generation' that is 2 pieces. Mine is a single piece drain valve.
