Jacques
STL Stinger Club
I think I will keep it like this.@xot1, since you swapped back to stock, would you consider installing aftermarket springs, but keep the stock shocks? Or, will you stay completely stock suspension, except for the Eibach stabilizers (swaybars) with the Mando moving forward?
Just purchased the Mando ECS10. Gonna be a fun filled install day sometime next week! Big shout out to xot1 for sharing this great discovery and to those posting who have installed this module. My brain is swelling with Mando info!
A video on an install would be fantastic! Frome the posts here, the install looks pretty straight forward, but can never get too much guidance on Stinger projects.Mine came in, going to find some time to document pictures/maybe a video on install today, and playing around with it. Probably ok to write my review in this thread? Will probably post during the week after I've gotten some experience with it.
Not true. The MY18 GT1 has ECS.correct. However that only applies for the 2019s
For the 2018s is only for GT2s
Really!? This app is a threat to the warranty, then.I can't see anyone using 100% setting on the streets for too long, that would be too much stress on the body and the car would also suffer.
The car was designed to take what KIA programmed for the permissible operating range on the shocks - this tuner takes it well outside that range.I think the car can take whatever this dishes out, or else the manufacturer would be guilty of exceeding the design specs.
Thank you so much for your post @Cyrus Duong! Love guys like you who take the time to post on this forum with detailed instructions! Hope your day was bright and relaxing! Following this thread for sure!
That is the arguable part: some dealers refuse to install aftermarket tune equipment; or work on cars that have it, threatening that warranty is being risked; other service departments have no issues with either. And now we have evidence that the drivetrain is way underused on the stock car; that in fact it can handle a lot more than Kia set up the stock car to do. So wouldn't that be true of the entire car? The Mando ECS isn't likely to exceed what the suspension can handle, unless someone actually abuses their car while in "stiffest" mode. A dreadfully stiff/rough ride isn't going to get used by any sane driver: but it might get tracked: and we know what Kia's warranty says about that! Tracking a car is "abusing" the car from a warranty standpoint. But playing around with real world road conditions won't risk anything.The manufacturer IS exceeding KIA's design specs, much like the engine tuners are doing with either ECU or piggyback tunes. The risk is ultimately with the purchaser who decides to modify their car.
You can always remove the module and there will be no trace of it. But who would wants to use 100% stiffness anyway?![]()
