Waynerm002
2500 Posts Club!
This is the one that goes into more detail:
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
correct. However that only applies for the 2019s
For the 2018s is only for GT2s
Thanks! Any hints about "add-a-circuit", as in, which fuses to tap into?
Is this: https://www.amazon.com/10-Pack-Add-circuit-Adapter/dp/B01DYQM6EO/ a compatible set? I haven't really dug into the Stinger much, but it seems like we have mini fuses, not standard?
I just installed the ECS10 this weekend. The install, well, I'd say 15 minutes...but actually 2.5 hours. What took so long, you say?! Well, I purchased the above mentioned add a circuit deal and these fuses are too big. I had to get one size smaller (Micro2). I thought, no big deal... but man oh man did I have to drive around to find the right ones. Well, mostly it was the adapter that I needed to find. I guess I could have done it another way or ordered from Amazon...but I was dead set getting it done and doing it this way (I'm odd). So anyway, the directions for the install found in this thread are spot on. The ECS10 its getting the job done for me. So...there's that.![]()
This one fits:Wait - the "mini" add-a-circuit linked from amazon above is too big? I ordered those, expecting a quick install. So I need to return those and get a different size?
This one fits:
Uriveusa 12V Car Add-A-Circuit... https://www.amazon.com/dp/B01LFXA5YQ?ref=ppx_pop_mob_ap_share
This one fits:
And if using the assessory the wire on the adapter faces left, drivers side. This saves figuring out the hot side of the circuit if you don't have a multimeter handy.
Not unusual to see those kind of big discrepancies between the two Amazon sites. I've bought stuff on Amazon.ca that was considerably cheaper than the same in the U.S., even before exchange was applied.Good grief, $8 in US, $31 in Canada. WTF?
Ordered mine - also with the correct fuse tap (micro2). Excited to see if it fixes that rear end from hopping or increases comfort. I find the range of change from the factory settings pretty minimal.
I have tested mine in the Basic mode and adjusted it over a few days. It takes some tweaking to find a good spot. So far though, the Comfort and Sport that are predefined in the App make the car ride much better than stock (with the in car setting in Comfort). I'll play with it more this weekend when I'm back in town.
What's your favorite Mando setting! Post it!Possible to get a new thread with peoples settings to share? Screenshots of the app is probably good enough. Curious to whay settings everyone is running?
I'd put the $ in sways over the mando. Sways transformed the car. Mando makes things a little different but not life changing. But Since the sways already tightened things up i prob see much less difference than mando on a stock car.From reading all these posts it looks as if this unit has been installed by 2 or 3 people here, am I correct in that? I am tempted but would like to see a few more reviews. I am most interested in ride quality and removing some of the "business" from the ride. I just don't see the stock settings changing much when I use them. They are slightly different but not that noticeable to me.
