Tonkabob
2500 Posts Club!
Some tips on installation
To get the side panel off you open the fuse box panel, put your hand in the opening and push the side panel out enough to get a gap and then you get a thin trim tool in the pop the panel out. Now remove the lower kick panel. There two screws on the side behind the side panel: one on the front door jamb and the other where the top right corner where the side panel was attached. Remove those. The last screw to hold the kick panel on is on the right lower side of the kick panel behind a small cover you remove with a pick. Once the screws are removed it’s a matter of popping out the panel. Lots of tabs holding it in so be patient and remember the OBD port and wiring is connected to the kick panel. Be cautious.
Now remove the lower steering wheel cover. First pop off the top cover behind the steering wheel. This gives you access to two screws. Each of the screws are only accessible if you turn the steering wheel first to the left and remove one screw and then to the right and remove the other screw, they are right behind the steering wheel. Now go under the steering wheel and and on the bottom panel there is a screw, remove it. Now you can remove the lower panel. It kind of slides out.
In the picture below you see three gangs of wire. Remove the tape on the right gang. The white wire, second from the right, is the 12v accessory wire - switched. There is a post previous in this thread that gives a link to a tutorial for which wire you should tap into - please go to that post, find the link, and read thoroughly before you begin. I’m not responsible here.
There are a couple screws or nuts to the left of the fuse box where you can attach the ground wire. As for where you connect the ECS connectors, right behind the steering wheel, on the bottom, there two or three connectors, but there is only one connector that will fit, pull it out put the connector in between and replug it back in.
Now turn the car on and make sure the green LED light on the ECS 10 turns on, if it is you’re ready to install which suspension set up you want from the app. Open up your app, go to the settings menu and connect to the ECS10. Once connected you will need to enable the software with a slide toggle in the settings menu. Make sure you route the wires neatly, I suggest small zip ties. I mounted the module to the back of the fuse box cover panel with double sided foam tape. Now go for a drive and enjoy. So far I find the sport option pretty good but it certainly isn’t the stiffest you can make it under the custom settings.
I’ll be interested in others set ups once more people start using this.
Great write up. Your instructions made the install super easy. Less than an hour. I taped the module inside the lower steering cover so its totally out of sight.
