The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
You can set "meth trigger = 1" to activate WMI on all maps, but only map8 has the progressive safety, where boost is raised as a function of WMI flow. Which is the best way to run it.
Map5 requests a fixed profile of up to 7psi over stock. Map7 requests a fixed profile of up to 8psi over stock.
Map8 is a variable boost map based on the WMI additive setting and WMI flow. And can run anywhere from map1 levels to map7+ levels depending on the additive setting. The additive setting is how aggressive you want the tuning under full WMI flow.
I run map8 with a 70-80 additive for 1/4 mile on E30. Depending on conditions and how high I want to push up boost. I want the safety to avoid knock until WMI is fully flowing and drop boost if WMI stops flowing. Especially during the 1/2 mile runs we often do.
Between 70 and 80 of additive, depending on circumstances.Excuse my ignorance, what do you mean by 70-80 additive?
70 additive means 7.0 psi of additive boost ob top of ECU boost under maximum WMI flow, and 80 additive means 8.0 psi.You mean 70 percent meth and 30 percent water ? Is that what it means
Thank you !!70 additive means 7.0 psi of additive boost ob top of ECU boost under maximum WMI flow, and 80 additive means 8.0 psi.
Boost additive.Excuse my ignorance, what do you mean by 70-80 additive?
Terry said:Map8 is a variable boost map based on the WMI additive setting and WMI flow. And can run anywhere from map1 levels to map7+ levels depending on the additive setting. The additive setting is how aggressive you want the tuning under full WMI flow.
Boost additive.
So what are the really bad reasons that you shouldn't use the washer fluid tank as a meth tank?
Not debating the use of 30/70 washer fluid or 49/51 purpose mixed meth, just the tank location.
The reservoir is already there, it's a decent volume, another bulkhead could be added pretty easily I'd imagine. Then you could run both from the one tank, Have shorter lines, not have anything inside the cabin.
I get that it is flammable but your washer fluid is already in there under the hood, by the engine, and it is 30% meth.
this video shows the boost juice cannot be ignited with a lighter. I'm new to all of this so someone will have to tell me what the concerns are. If your car is on fire your screwed either way.
How though?I am not expert on meth.......But that doesn't sound too safe.
I am sure there are safety reasons not to use the washer fluid reservoir.
I don't think I can get the 30% meth stuff in South Carolina, does that count as a negative? lol. Normally you need the -32F stuff for it to have meth in itHow though?
Positives / Negatives / and a wash (=)
+You won't need to install a separate tank
+You will have shorter lines all consolidated in one area of the car, you won't have to tear up the interior to run lines / mount tank
+You won't have meth inside the cabin
+An uninstall would be easier and quicker
+If you used washer fluid you could tell the wife that it always needs to be topped up with each trip to the fuel pump for some strange reason
=There is already flammable liquid in there. (or apparently not flammable)
=You will have lines caring meth through the engine compartment regardless.
=Per my reading boost juice can be used as washer fluid / ice melt on the windshield
-Need to add a bulkhead to the washer fluid reservoir and make sure it does not leak
