Nice setup. What do you have the front camber set to?
We just got Riaction coilovers installed on our
G70 over the weekend too. Since we already done Eibach lowering spring install
twice, this was pretty much a walk in the park. Although, doing it in 100F Summer heat wave was no joke.
Picked up this set used at a bargain price from a Stinger owner. Needed a bit of TLC, but now good as new! We have a special AutoX event coming up mid-Aug at Eagle Canyon Raceway, dubbed "1 MIllion Cones".
Should be a good one, especially for testing out the new coilover suspension.
I moved the rear anti-roll bar setting back to the "soft" hole, matching the front. Now that we got proper front camber at -2.0deg F&R and adjustable shocks, which are the right ways to reduce the pesky initial understeer, I wanted the anti-roll bars reset to baseline.
IMO, lightweight wheels, 18" tires with good compliance, coupled with well-damped shocks and stiffer springs, for excellent chassis control, make for optimum grip/handling. Stock setup with under-damped shocks, softs springs, coupled with heavy 19" wheels and stiff sidewall tires, is just @ss backward.
