Devin
1000 Posts Club!
Sorry to hear about your printer, what model did you get. I just bout a Creality Ender 3 V2 (had an old wanhoo i3 duplicator collecting dust because could not get good prints out of it). Man has the tech improved ...soooooo much quitter, and much easier to get good prints.
I will let you know if I get my intakes before the 10-12 weeks since you had to cancel![]()
MP Select Mini Pro V2. I've replaced the X and Y bearings each, heater cartridge twice, the board fan, the extruder, the hot end and the heat break fan. The latest "compatible" E3D high precision 12V 30W heater cartridge gets the hot end up to 120 and then the printer crashes with this error:What kind of printer do you have? I can't think of a single component on my printer that would cost more than $75 to replace.
Code:
Connecting...
Printer is now online.
Error:Heating failed, system stopped! Heater_ID: 0
Error:Printer halted. kill() called!
I tried a PID autotune to 210 C which worked, but the cooling fan never turned on and the bowden tube capture nut (not sure what it is called) in the heatsink melted, so now I have to replace that and the heater cartridge. I'm done with this thing.
I'm looking at an Ender 3 S1 now. I like the direct drive, the gantry with the double Z motors and the flexible build mat. As @boosted1g said, the technology has really changed.
