I'm looking to buy a set of TSW Silvano wheels for my AWD Stinger. (I can't post links/images yet, too new)
They come in 19x8.5 and 19.9.5. I'm leaning hard to a square setup with 19x8.5 all around, so I can rotate front and back and extended the tire sets life.
I need you bigger heads on here to help me decide on the details.
The wheels come in 20, 30, 40 offset. Offset of 40 seems to work the best for front and rear, but after doing some reading I believe I'll be needing a pair of spacers for the fronts to help clear the brakes.
FRONT: Inner Clearance 12mm LESS, Outer Position THE SAME
REAR: Inner Clearance 7mm MORE, Outer Position EXTEND an extra 7mm
I've seen +3 and +5 mentioned, that right? Also what brand of spacers are common, I've never used any in the past.
As for tires, the undisputed winner looks like 255/35 for the 19x8.5 wheels according to everyone.
I'd be ever grateful for the help with offsets, spacers, even wheels. THANKS!
