Hell yea man. I feel a LOT more confident after our back and forth. Planning on installing this coming weekend! Are you running 93 or a mix?I just actually finished running it threw the fire wall super easy. Just used a old school metal hanger. Even used my dremal to notch out plastic so wires don't hit nothing when closing the hood. I should of just did this yesterday! Its easy!
I'm glad we have 93 in FL. Any reply from Terry regarding the maps/graphs?91 where I'm at. I will figure out a mix once I get going!!!
Can anyone help with the fuel wire ADAPTER for the 2.0? Is the signal wire the RED wire, OR the black wire on position 2?
That's what I thought. I watched a video on how to install on a 2.0, and the guy used the red wire to puncture. Just want to be 100% sure before I hit the wrong one. Thanks!
Anyway to know whether the fuel wire adapter is working as it should? I installed it but don’t feel the difference at high rpm on map2.That's what I thought. I watched a video on how to install on a 2.0, and the guy used the red wire to puncture. Just want to be 100% sure before I hit the wrong one. Thanks!
Thanks guys, will do that. Just got to find a road to do a pull, kenna of hard in SG
Green Line - StockHaven't seen any Dyno graphs for 2.0 with JB4. You may have seen my other posts to include my Dyno with mods and Racechip RS. Just swapped over and installed the JB4. Huge difference so far. I'm not sure but the Racechip RS may have been the equivalent of the Map 1 on the JB4. Hard to believe my car has gotten WAY WAY faster than it was. My mods may be helping as I have read that the JB4 responds to mods better than Racechip. There is no pause in gear changes as with the Racechip......just a constant pull. I can feel my rear tires almost losing bite when I go WOT at 30, 40 and 50 mph. My mods are Custom Catback Race Exhaust, HKS plugs, Injen Intake and XLR Throttle Controller. I'm looking at getting on the Dyno this weekend and will do 3 pulls on Maps 1, 2 & 3 (running Shell 93 with STP Octane booster for Map 3 to get logs). Fuel wire not hooked up yet. No E85 in my plans but if so, I will probably add Oil Catch Can, Blow Off and possibly upgrade the Intercooler. Standby for the Dynos.
Welcome! Am on an Injen intake and secondary catless. It’s hot and humid here so stock numbers are lower due to the climate.Thanks Robs! My first time seeing Dyno numbers on the 2.0 with JB4. I've searched many threads.....or so I thought. Nice numbers by the way.
Question: I thought the base whp for the 2.0 was 199. Any mods other than the JB4 if you don't mind?
I was told to call the shop this morning to squeeze in Dyno time. Map 3 will be my highest for now. Hopefully they can get me in. Will post today if I'm a go.
