Push it out towards the firewall. its held in the little clip via friction. Then once out of the bracket you can unclip it. This is a pain in the ass in the tight space behind the engine. Then clip in adapter and put adapter in bracket.I’m wondering the same thing? @Terry@BMS
The hardest part was figuring out where the connections are on the 2.0L. Check out post #27 in this thread for pictures on the locations.I have a 2020 Stinger GTLINE 2.0 and I need guidance on how to install the jb4. Can you help a brother out, there isn't much content for the GTline and I want to do this right. Your help is appreciated.
did you try the map 2 i want to install the jb4 on my car but im wondering the diffrencesMy completely stock g70 manual 2.0t map 0 and map 1 dyno runs on 91 octane if someone is looking for a 2.0t dyno result
I dont have 93 octane availabledid you try the map 2 i want to install the jb4 on my car but im wondering the diffrences
That sucks not having 93 available. The 2.0 is a beast in Map 3 and even more so in Map 5 with Boostane. Should be getting a Dyno for Map 5 soon. Will post results. Looking to shoot past the 337 bhp (263 whp and 287 wtq) obtained on Map 3.I dont have 93 octane available
So your dyno # on map 3 was 263? Am i reading that correctly? Are tou running both jb and the racechip?That sucks not having 93 available. The 2.0 is a beast in Map 3 and even more so in Map 5 with Boostane. Should be getting a Dyno for Map 5 soon. Will post results. Looking to shoot past the 337 bhp (263 whp and 287 wtq) obtained on Map 3.
Keen for some pictures of this as well as I'd like to do the sameHey man could you send a picture of the way you ran your cable through the door jamb? I’m thinking it’s easier running this way so it’s way to take off when going in for service
Yes... 263 whp on Map 3. The 232 was Map 1 but the engine coughed (blue lines). Map 2 (not recorded on paper) was 240 whp. I didn't have the fuel wire connected for any of the runs. With a 23 whp jump between Map 2 and 3....i can't wait to see what Map 5 does on the Dyno. Hope to cross 300 torque to the wheels!So your dyno # on map 3 was 263? Am i reading that correctly? Are tou running both jb and the racechip?
Hey cant complain. I wasn't even thinking race chip throttle controller. All makws sense know. Im a little slow at timesYes... 263 whp on Map 3. The 232 was Map 1 but the engine coughed (blue lines). Map 2 (not recorded on paper) was 240 whp. I didn't have the fuel wire connected for any of the runs. With a 23 whp jump between Map 2 and 3....i can't wait to see what Map 5 does on the Dyno. Hope to cross 300 torque to the wheels! View attachment 70705I am running the JB4 piggyback together with the Racechip XLR Throttle Controller. Last Dyno attached. Keep in mind that those numbers are peak.
Good deal. I use Map 3 for my daily drives and toss in some Boostane on a tank full every now and then to run Map 5. I can seriously feel the difference between the two.Hey cant complain. I wasn't even thinking race chip throttle controller. All makws sense know. Im a little slow at times![]()
Actually i asked because I hit the dyno this past weekend with mine. And wanted to be sure i was at least in the same ballpark. Which i am. Appreciate it
Im sure the normal heat soak didn't help I n the 2nd 3rd pulls. I know it got me
Because that's still about 60-80 WHP and 80ish WTQ below a stock RWD GT.
correct however you have to take into consideration the weight difference between the enginesI have the BMS controller. I’m loving it.
