The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Low fuel quality ? Low octane ?I see some timing drops here on the start of the first run. If it's a trend and doesn't adapt out then might make sense to drop down in boost in that range with a custom map6.
The 91 Shell V power is what I had to change to because of the unstable gas , And so far here in Kelowna BC it seems to be the best gasLow fuel quality ? Low octane ?
Next time i will change gas station for shell 91 for try
Right low fuel quality
Log SHELL 91 v power with 250 mL octane booster.Right low fuel quality
Mid throttle ar low rpm. Not ear "tic" noise with v-power shell
Map6 custom for not ear tic noise at low rpm ??? Looking good for you ?I see some timing drops here on the start of the first run. If it's a trend and doesn't adapt out then might make sense to drop down in boost in that range with a custom map6.
I dont anderstand why sometime i ear one or two tic noise when i push accelerator at low rpm and high rpm i have good timing. Bad plug ? But only 1000 mile.Yes looks fine to me if it's getting the job done!
I added another brand of octane booster since I heard this noise (hy-per fuel) bad octane booster maybeDon't know but I can see timing isn't perfect, so likely a boost or octane issue. Did you up the octane to see if it goes away as a test?
I had to use 6 to 7 full octane points to get a solid 94 with even v power Shell 91 but it works and if you use Boostane octane boost then for sure use 500 mils to 60 litres of gasI added another brand of octane booster since I heard this noise (hy-per fuel) bad octane booster maybe
Ok. But not boostane here. VP racing octanium is good ?I had to use 6 to 7 full octane points to get a solid 94 with even v power Shell 91 but it works and if you use Boostane octane boost then for sure use 500 mils to 60 litres of gas️, hope this helps
The octane boosters are pricey to say the least but NOS ,Lucas and Royal purple should give a solid 91 on 91V Power Shell , however if you need a solid 93 0r 98 that is tuned for it then order BoostaneOk. But not boostane here. VP racing octanium is good ?
Boostane is make with MMT ?The octane boosters are pricey to say the least but NOS ,Lucas and Royal purple should give a solid 91 on 91V Power Shell , however if you need a solid 93 0r 98 that is tuned for it then order Boostaneor check out the local tuning shop s to see what they are selling for Octane Booster s
this should help
safe driving !!
Yes , and I believe most of higher quality booster s are made with certain amount MMT ,and is a fuel stabilizer as well but is hard on plugs lolBoostane is make with MMT ?
