turboAWD
1000 Posts Club!
do the coil pack connectors just pull apart or do you have to press a release button
As I recall, they just pull apart. I think it's easier if you twist while doing it - they should spin with a bit of pressure..
Replaced plugs yesterday and boy was I nervous. The last time I replaced plugs on a car was over 25 years ago on an 86 Toyota Celica GT and I cross threaded one inside the motor. Had to tow to a garage and took them several days trying to get it out. Actually broke off inside the block. I said I would never fuk with plugs again. Thanks to this thread and a few videos, I did it!!! My only advice it to make sure you have a swivel magnetic spark plug socket, a magnetic 10mm socket, a magnetic pick up stick and about 3 hours. Passenger side took the longest. Removed the coil pack in the back first, then the middle one (had to unplug connector and separate the coil into the 2 parts, and then removed the front one (had to unplug connector and pull coil pack towards the front). Driver side was very quick and easy. What took me so was I kept dropping the coil pack bolts and sockets down in the motor, then having to find and fish them out. Never found 10mm socket and 1 bolt. I am sure next time will go a lot smoother.
Ya those coil pack bolts were a p.i.t.a. the single biggest time consumer for me when I did them. Some guys have swapped them out, I think I'll do that next time as well.Followed all the tips in this thread and knocked it out in just over an hour. Some frustrating moments trying to rethread the coil pack bolts, but all in all not terrible with the right tools.
