Added v13 BETA firmware to get some feedback and logs on the minor changes.
v13 BETA
1) Adjusted boost scaling in JB4 app to reflect ~10% higher boost levels to better match up the JB4 with external boost gauges.
2) Revised double PID fuel control system for smoother performance and easier user adjustment
3) For people who prefer to custom tune improved user interface for user adjustable fuel control. Enabled by setting options bit1 on, the fuel bias values will now represent the "target" air/fuel ratio. e.g. 120 = 12.0:1, 125 = 12.5:1. Actual AFR will generally be richer than the target. Current logic allows for leaning AFR from factory only. The default JB4 setting is 120. You may require a JB4 Mobile app update to allow values of more than 100 under fuel bias.
4) Logical changes to facilitate upcoming electronic wastegate (EWG) control.
5) Increased sampling speed while logging is active to further smooth out performance.
6) Revised map4 VALET map to make it more usable.
7) Revisions to E85 auto tuning map for those equipped with a Fuel-IT Flex Fuel sensor.
8) This firmware is the same as V13_T13 firmware for those who have been helping test it.
v13 BETA
