Asking the group for some insights!
Thanks in advance.
Looking to keep my oem rims for winter and get new summer rims.
Fast Wheel Aristo (either gloss or machine black)
The options are
19x8.5
19x9.5
19x11(think this out of the question)
Off set 30 or 40
I was leaning towards squared set up with 19x8.5 30 (question remains if 40 offset is better...thoughts??)
Tires will be 255/35
I know some are running 19x8.5 30 with no issue, no with this wheel design, what is your guys take on the nicest set up?
Keep squared or staggered, why?
Running 8.5 or 9.5?
30 or 40 offset?
Thanks!!
If anyone has those wheels, please share pics, I couldn’t find any testimonials on the forum.
Unless you put up with some poke, I don't think that 9.5" wide on the front will clear the Brembos.So you saying 19x9.5 30 instead of 19x8.5 30?
I had plans to use the oem tires until they were done as the car was just acquired in May’19
My 19x8.5 are 40 offset. Stock tires. So, stretched half an inch more than OE wheels.Awesome , thanks, I wasn’t sure.
Therefore with this rim the ideal set is 19x8.5 30 offset ( which mean I will even be able to reuse the stock tires too)
lol hence why I came here to triple check myself before ordering the winter tiresThe amount of bad information from "experts" on FB makes it useless for anything other than sharing memes. "I read it on facebook, it must be true!"
I found and saved this wheel to tire size matrix along my travels. I believe this is the source.Hi everyone,
I am getting mixed info from the FB group ... therefore I will rely on the expert here from the Forum.
running 255/35 all around for my winter set on OEM rim - I know it wont be an issue at the rear BUT I was challenged it would work on the front and to not do 255/35 on an 8 inch rim ...
I seen that set up done on here so some have done it , I am inquiring to make sure it is the right way to go , need to order those tires asap
Thanks !
Hi everyone,
Thanks !
