Cyrus Duong
I don't think so.
But I may be wrong so I'll ask them.
Awesome thank you. If I'm wrong, then yes we'd probably want to use the advanced tab like you suggest a few posts ago.
I don't think so.
I think so, because I'm confident in saying that the suspension got more "secure/planted" the faster I went. A "bounce/float" tendency at legal speed would translate into a virtual bound into the air in back if the suspension didn't adjust to speeds well over 100 mph. The highway I was on (95 in Oregon) has humps along a considerable part of its straight stretch. A "floaty" car would get worse the faster you went: the Stinger took each hump as a single, instantaneous "event", over the top and flat to the road surface again: no "bounce" or "float" whatsoever. Had it been otherwise, I'd never have gone that fast in the first place but backed off long before I got anywhere near 150 mph. So the factory damping and rebound has to firm up with increased speed. That is the base programming that this Mando ECS box is an "additive" for.From factory it would make sense for our vehicle to adjust the compression/rebound with speed.
Have you ever driven a german sport car (M,AMG,etc.) at high speed(>130mph)? It is incredibly stable.A "floaty" car would get worse the faster you went: the Stinger took each hump as a single, instantaneous "event", over the top and flat to the road surface again: no "bounce" or "float" whatsoever.
I only had stock suspension. No I have not driven a German sports car. I'm asking about the non ECS Stinger. Since I put in my Eibach rear bar the already well behaved rear is even better. I have no way of quantifying "incredibly stable", since I remain impressed by how my AWD GT1 remained stable at any speed.Have you ever driven a german sport car (M,AMG,etc.) at high speed(>130mph)? It is incredibly stable.
If you do so then go back to the Stinger and you will notice the floating/bounce for sure.
Some will say its because its a GT, but when you drive it like a sport car, it needs more stability. Thats why so many people do sways and springs.
Here's a limited illustration of the stretch of highway I'm talking about: the straight overhead satellite image is given side on perspective using computer imaging to fake it; and the wiggles seen here are actually humps in those places.
(But how does a Stinger with no ECS compare? Would it bounce up and down on those humps? And if not, why not?)
I got the answer from the Mando ECS10 developper.Awesome thank you. If I'm wrong, then yes we'd probably want to use the advanced tab like you suggest a few posts ago.
Typical problem when a suspension is not well adjusted.Making matters worse, is that the front and rear don’t bounce together (flat/level body). They both oscillate on their own and often times takes more than one cycle dissipate the energy of the bump or irregularity.
It has a shorter wheel base so it may react differently to the same bumps.I did test drive a G70 3.3 with regular suspension and found it to be firmer and better composed than the ECS Stinger at most times, but that car too had an excessive (but less than Stinger) amount of bounce over larger undulations or sharp elevation changes.
The Mando ECS10 replaces the stock ECS values and is NOT an addition nor a substraction to the stock values.
So that implies:
1. Changing from Eco/Comfort/Sport while having the module active has absolutely no effect on the suspension
2. Setting fixed stiffness values (not changing with speed) on the module will apply these exact fixed values for the suspension, and not increase or decrease values from a variable stock profile (= doesn't work like a piggyback)
This is something I also wonder about. It may have an adaptive curve too.Wonder if Basic tuning has an adaptive curve built in even though it has/shows one value?
YesExcuse my ignorance, but what is meant by an adaptive suspension? Different settings applied by the computer under different conditions such as speed, cornering and road condition?
For me, after driving a loaded G70, it did remind me of a 2008 or 2009 BMW 335 with M-Sport package. It was a nice, buttoned down ride. The car was nimble through traffic and corners and such a joy to drive. I opted for the 535 M-Sport though, for the extra space. I'm getting closer with how I want the car to ride by tuning for a different feel at different speeds. The quest continues.
So that implies:
So Ty from what you are seeing it would seem the ECS system in our cars is adaptive, correct? It is changing voltage to the shocks depending on circumstances?
Yes, both the Factory and Mando suspensions are adaptive.
The Stinger RWD with ECS tends to run a touch too much compression damping to completely smooth out road grain and texture. (The Mando works wonderfully here, reducing the compression harshness but adding in more rebound). It takes a fairly smooth road for the Stinger to glide like a true luxury/performance sedan. Throw in a bit of road surface irregularity and things can deteriorate noticeably.
I think Kia did this to impart a sporty demeanor to what really is a super soft suspension.
On Hwy OR 95 at speed I felt none of this. The car simply negotiated each "hump" in a single movement; like something pushing up from beneath and letting go: the car rose and dropped without subsequent "cycles" of movement. Again, had the Stinger done what you describe here, I'd have backed off and never pushed it that fast.… few of the many cars I’ve driven recently have looser body control than the Stinger with ECS. The body simply moves up and down more than other cars. Making matters worse, is that the front and rear don’t bounce together (flat/level body). They both oscillate on their own and often times takes more than one cycle dissipate the energy of the bump or irregularity.
