Cyrus Duong
I'm trying to think of a way I can introduce a grounding spot/plug that isn't too obvious that I can plug my stuff to ground into and be easily removable later, like for this mando unit.
You can still unplug the actual power cord from the unit but then it'll still be attached/hanging in the fuse box/door area... Idk I don't believe they'll ever need to get in there for just changing oil... But if they are diagnosing anything related I'll be sure to remove it before taking it in...
The JB4 I know will be coming off always before it goes into the dealership. This mando unit... probably don't need to be removed every time. Just specific cases where they might dig around in the fuse box area or check-in/around the steering column.
