Check this out!!! (ECS control module)
Installed mine last night and as soon as I pulled out of my garage, I felt the change! The ride is smoother in comfort mode with the comfort mode on the App, switching the car to Sport mode was even nicer. Using the App's Sport mode with the car in comfort made for an even better driving experience! I met up with my buddy for him to check out the driving mode and he immediately went into to custom and maxed the ride settings or so he thought, he tightened the front and not the back (50%) and it I was quite happy until my other friend commented, "if you are going to max it out, you need to do it with everything." He changed it and went for a drive. Wow, what a difference! Rear sway bar needed, what, no! He was in sport mode, manually shifting and just aiming for rough spots in the road. He was impressed! This is a man that loves speed and drove a modified EVO with 500+ hp, hoping to talk his wife into letting him mod her Stinger with a JB4 tune with intakes and exhaust, so he can take on everything he can find on the road.
The car is so much better with this unit installed. The maxed custom setting was really great to drive in my area, which has a lot of smooth roads. Encountered some not so great roads and felt that jouncy feeling that was mentioned. Certainly not something I want to experience every day. Will have to play with tuning it more but I am really happy they made this mod! Feels like I got a new car! No need to lower it to get better handling (for me), really don't feel the need for a rear sway bar at this juncture, she is now more than a Grand Touring car! My buddy feels it would be a good car to track with the setting maxed, all I know is that the car rides like and fells a lot better no! Highly recommended mod and the best investment based on the price. Big thumbs up here!!!
Took a few vids to help
Thanks for the video, I do get the visual I neded before making the purchase. Cant wrap my head around the power though, where did you find the piggyback fuse and to which spot did you connect it?
I read some left the devise tucked in behind the steering wheel , where did you leave yours?
Btw, nice CF set!! I have seen the steering wheel before but are the button layover ones??
I used the posi tap as well on the white wire. Took 1 minute. I was planning on using a fuse tap but i already have a fuse tap on the accessory power slot which blocks the second accessory power slot. Posi tap was much easier and there is already an in line fuse included.
Assuming I still have my accessory power slots clear, do you have any directions / explanations of how to do that? What fuse sizes are we using / what fuse tap would work? I'll do a posi tap if needed, but would prefer a fuse tap..
Nice to see all the positive feedback and know people can actually feel the difference and not be some placebo effect.
So for those who have anti sway bars, does installing this ECS module still make sense?
I think the folks that are looking for that extra performance will probably want to install one as well. I can say, that so far, maxing out the setting, it certainly doesn't seem like you would. However, making it hard all around may not be the thing everyone wants to do. I'll have to play with mine more to find that sweet spot.
100% max would probably be for auto-x or track, I would imagine?
Yeah i just drove down my semi bumpy road maxed out and it was un bearable, mostly due to the bouncing.
Sways was much more noticble than running the chip in sport. I havent hit the twisties hard yet but if i only did one i would do the sways.
Thanks. Do you think SPRINGS are still worth doing? Or can we replace springs with the ECS10? I had previously planned on springs + sways, just wondering if I should still do that. Not interested in any lowering - I need to clear potholes, bumps, driveways, etc..
And wouldn't be bothered by doing springs, sways AND the ECS10.. Just wondering about springs/ecs10 being redundant..
Springs can be done with this, as long as you don't go for too big a drop, then the shocks will still be operating within their expected range of travel.
I'm sure they CAN - my question is, is it still recommended? Which have the least drop - Ark or Eibach or Godspeed?
The ECS module doesn't change the operation of the shocks in terms of length of stroke.
Even with the stock setup, there's clearly going to be a slight mismatch between the stock springs and the settings on the shocks.
I reckon I'd go for the ECS module first if you're trying to fix suspension behaviour, or the springs if you're trying to fix ride level (I honestly think the car rides just a fraction high, and given we only have RWD cars here in Australia, am considering the H&R RWD-specific springs for my car).
I may yet go for the ECS module as well - I'm not terribly happy with the stock comfort and sport setup, I actually think the stock springs are a fraction too bouncy to suit though, so I suspect that in the end, springs and ECS will be the way I go.
If that then means I can skip doing swaybars, that's a good outcome.
The Eibach spring mod was the best alteration I've done to the car, it gets rid of that bouncy feeling that Manaz is talking about. There is more of a luxurious feel to the ride, the rebound appears more controlled.
My front sway has made a bit of difference but the rear is still unsettled . Next step rear moved to firmer setting. I don't have the ESC module.
I’ve been testing the module for a few weeks now and have made some observations...
I’ll preface this by saying that my complaints about the factory suspension were few, but specific, and (in my mind) major. My car is a 2019 USA Stinger GT2 RWD.
The stock suspension is far too bouncy. This is an issue both front and rear.
Additionally, absorbance of small bumps/road texture leaves a bit to be desired. There’s most always a stream of jitter/patter/ and road feel unless the road is almost glass smooth. On these smooth roads, the car glides along like a Mercedes. But add in cracks, blemishes, and broken surfaces and all are felt too clearly in the cabin.
The suspension actual rides nicely over potholes and actual bumps of medium to small size.
It just struggles to filter out the minute bumps and texture.
Another issue is the skittish rear end while cornering on bumpy surfaces. My car only exhibited this behavior on the worst pavements.
My last major complaint is that the body does not move as a whole. You can always sense one (or several) corners of the car dipping, rising, leaning, or slightly wobbling in response to road conditions or steering inputs.
Now, to the Mando...
The suspension behavior is improved all around.
Vertical body motions are reduced at both the front and rear of the car.
The suspension masks road texture a bit more thoroughly.
The skittish rear end is tamed to great effect.
The Mando is a definite improvement over stock.
That being said, it does not perfect the stock suspension.
There is still far too much vertical body motion, both front and rear, over bumpy/lumpy roads.
This applies to all of Mandos predefined modes (Comfort or Sport).
Neither of the settings provides the flat, solid, and mostly bounce free ride that I desire.
Seeking more, I moved on to the Customizable setting in the app...
I was hoping to be able to make the ride relatively bounce free and solid.
Well, if you stiffen the settings too much the car becomes bouncier. Go too high in stiffness and you remove the slow relaxed bounce of the stock suspension and get a high frequency go cart bounce instead.
Perhaps this is due to mismatching the compression/rebound settings in The Apps custom setting.
I’m still playing with the custom setting to see if I can get a flatter ride.
I’ll have to reverse engineer the app to see what ratio of compression/rebound damping they are using in the preset modes and work from there.
On this note, I noticed something. There are differences between the IOS and Android versions of the app.
The significant difference is that on the custom setting in the Android App, you have to specify rebound and compression (labeled handling/ride in the app) separately. This makes it very easy to end up with a bad rebound/compression mix, until you get a feel for where it should be.
On the other hand, the IOS app Custom setting controls the rebound/compression ratio together automatically.
This has made it fairly easy to get my best calibrations yet. Using the IOS apps custom setting, I am fairly close to an “ideal” tune. Still getting there though.
For those wanting to know if the Mando can replace sways...
Not on a daily driver. You will still want sway bars, even with the Mando.
Sure you can set the shocks stiff enough to just about eliminate all roll, but the ride quality suffers immensely at those elevated firmness levels. Even smooth roads will cause the car to rapidly pogo up and down (particularly at the front) at the settings required to control body roll like sways would. I may revisit this statement, as my custom setting gets dialed in more precisely.
And last but not least, and here’s the big one.
I found the reason why Mando was reluctant to sell these outside of Korea...
The Stinger is available in several markets:
North America
Korea
Russia
China
Europe
Australia
Each one of these places have their own suspension tuning.
Each place has a specific hardware (shock) and software (ECS Computer) calibration.
Parts (and tuning) also vary according to trim level. AWD and RWD use different physical shock absorbers too.
I mention this to highlight that the MAndo was obviously designed and calibrated for the Korean market Stinger.
We use the same springs as that Korean model, but our shocks are different. Plus, the OEM Kia Suspension Computer firmware is different to accommodate those different shocks as well as regional ride/handling objectives.
So, when we used the Mando on our North American shocks, and on top of North American OEM Kia suspension computer programming, we are certainly not getting/experiencing what Mando had in mind. Is it better than stock? Yes. Optimal? No.
This is probably the reason I cannot completely get rid of the front bounce, even with the Mando. Our front shocks and factory programming are simply too different from the Korean shocks the tuner was designed to work with.
Mando has said they are looking at offering the tuner here. If they do, I’ll definitely upgrade to a North American Mando (if it’s different), because even this Korean version is quite nice.
And on a somewhat related note, my Kia scantool (not Mando) just got updated...
Low and behold, Genesis G70 settings have been present and stored in the Factory Stinger ECS Computer this whole time. I coded my factory ECS to G70 3.3t Dynamic and that works just as good as the Mando does!
If you don’t want to spend for the Mando, dropping by the local Hyundai dealer and having them code your ECS to G70, works just as well and might be potentially cheaper (just the cost of coding).
I’ve been toying with coding my ECS to different models and also using the Mando on top of that Kia coding to see which combinations produce the most refined ride and handling. A long process of trial and error.
Hi Ty,
What Scan tool are you using? I have been looking for a dealer level tool to investigate programming and deeper coding options.
North America
Korea
Russia
China
Europe
Australia
Hi Ty,
I am using this Gscan2 by Gitauto.
This same company supplies the OEM Kia scantool.
Accordingly, they tend to get Kia/Hyundai/Genesis updates rather quickly.
I tried 2 other scantool before finding this one. None of them could access any of the Stingers coding functions because new Hyundai/Kia vehicles/platforms have a new “Security Gateway” that blocks access to bidirectional controls and coding. There are a lot of tools that are still limited to just basic OBD2 functions on the Stinger, because of this.
The unit was pricey, but I love it. $2.5k
A new Gscan3 has been released overseas, but is not yet available here or many other places.
That being said, this G2 does everything I ever ask of it.
I also tried the Autel MS906bt. $1.2k
It was half the price of the G2 and a bit faster moving through the menus too.
But, it was not updated to work completely and thoroughly on the Stinger yet because of the Security Gateway.
That was back in March. It may very well be compatible with our cars by now. It was especially nice because it had a Bluetooth adapter that plugged into the Obd2 port, rather than the wired connection of my Gscan2.
Whatever you buy (if other than the Gscan2), confirm that the tool works with the new Hyundai Kia Security Gateway.
I’ll be starting a separate thread soon about some of the nicer modifications you can make with coding.
Thanks for the updates, Ty. I've seen at least a couple of recommendations for "still need sways" - what do you think about springs?
Wish you'd found this G70 dynamic setting BEFORE I bought the Mando, but, playing around with it myself will be fun - I think. Although I have android phones, so I'll have to play around with the 2 settings manually and see what I can find.
thank you for your insight ! since they are now selling on Ebay, wouldn't they just have hold off to do so if they were looking to sale the unit to the proper region with the adequate codding ?
I’ve been contemplating springs too... But I can’t really state what they’d do for the Stinger (with or without Mando). I’ve only used springs on one car in my entire lifetime. I had a 98 Accord EX V6 back in 1998. That car had an amazingly stable suspension system. My only complaint of it was that it had more nose dive and rear lift during braking than I was used to from my previous Hondas. So I bought H&R OE Soft Sport Springs. They lowered the car .50 inches in the front and .75 inches in the rear. Installed them and they did nothing to help the brake dive. I was disappointed. But then I hit the first corner and then some on/off ramps and I realized WOW, the car cornered completely flat and it felt like it was glued to the road on rails. Very secure cornering. Ride quality was just as composed and smooth as stock at all times. There was a touch of added firmness over potholes but the Accord was so well isolated and the springs worked so well that most people wouldn’t even notice. I ended up keeping the springs because they made nothing worse but improved body roll, increased steering response, and made the steering heavier.
As for the Stinger... I’m not sure what springs will do, because the stock shock tuning is so poor. In my mind, it seems likely that adding a higher rate (lowering) spring to the Stingers already flaccid shocks would add good roll resistance and steering response , but would also ADD to the bounce we already experience. Every time someone posts here about having added their new springs, the first thing I ask is is it bouncier than stock? In the cases of both H&R and Eibach, some say yes some say no. I am convinced that some people don’t care about, notice, or are not bothered by bounce. That being said, I feel that others drive on relatively smooth roads and don’t get into situations where the car bounces.
Here on the forum, most people report that Eibachs reduce the bounce. Again, I’ll have to test a set to be able to describe how they effect this chassis. I do know that the F30 BMW 3 Series suffers from the same type of underdamped suspension we have and when adding springs to those cars you get more stability, but also more bounce. A stiffer spring generally needs a stiffer shock to control it.
I’m more likely to add sways first. The reason why is because when trying to control body roll through the app, it’s far too easy to degrade ride quality and balance. I might end up with sways and springs though... I think the App may not control brake dive as well the stock ECS settings. But this may be a side effect of my brake pad selection. (I’ve got grippier pads on the rear - Euro Stinger pads).
In any event, I’ve wondered several times “how would the Mando feel with stiffer springs?”
It might be a nice addition. That being said, the Stingers problem is not the springs. The stock spring rates are quite decent. It’s these shocks that are holding us back. Everything else is just a bandaid for the poorly calibrated shocks. Since a good shock is not available, I’m happy with a bandaid, that works...
About the G70 suspension coding. I almost flipped when I saw those settings! Now I have to go drive a G70 with the Electronic suspension... When I test drove the G70 this summer, I specifically chose a model with the regular suspension thinking that G70 ECS had the same bad habits as ours. I drove a 3.3 RWD Advanced with regular suspension. It was smooth, compliant, and firm. But it still had bounce like the Stinger over some larger dips and bumps (though to a lesser degree). I immediately brought the car back and didn’t look any further.
Now that I have access to G70 coding, I need to try an Adaptive Suspension G70. Maybe it’s what I’m looking for. If so, I’d end up buying G70 Adaptive shocks and fitting them to my Stinger. Then, just coding them in.
But I’ve seen a couple G70 video reviews and I can always spot what looks like a reduced version of the Stingers bounce. So, we’ll see.
That Android phone will do just as well for tuning... Especially as more and more people get the Mando and are able to start reporting and comparing custom settings. We’ll eventually figure out what works best. If you find you can’t get a good custom setting with Androids separated controls, you can always grab an acquaintance and/or their iPhone for a bit of quick testing and experimentation.
You’ll definitely enjoy playing with the Mando settings. Ever since I started tweaking the suspension, I spend more time on “test roads/routes” than I do normal driving. It’s quite amazing and engrossing making changes and seeing how the car responds. You can really get carried away with tweaking the dampers.
