I'm in the same ball park. I want to do a jb4, but I also care about warranty a lot and want to make it as stock as possible for service visits. So changing plugs and running OBD cable through the firewall take this from a quick plug and play to something a bit more complicated.
Is running map 1 on the factory plugs with no canbus connection safe and acceptable? I know this would be leaving power on the table, but it makes it a lot easier. Map 1 with an intake would still help I feel like, but I have never driven it. Thanks for the help.
You guys over complicate the hell out of things. It’s like people hear, “run a wire through the firewall...” and instantly go:
Running the single wire for the OBDII takes 2 minutes (see video below), it’s not some laborious activity. While you can run the JB4 without the OBDII connection, it’s there for an important purpose and should be used to provide the unit with as much data as necessary. When you want to go to the shop, simply unplug the OBDII and tuck it up into the dash if you don’t want to spend the 30 seconds removing the wire completely.
Changing the spark plugs is regular routine maintenance. On a turbo motor, you’ll have to change them more frequently than a NA engine anyway. If you’re not mechanically inclined, take them to a shop and have them drop them in — you then drive worry free for the next 20K miles, and you’ll just change them again as a part of standard routine maintenance and does not hinder or impact the vehicle’s warranty.
