Tobstertx3
Texas Stinger Swarm
Will get better pictures for you, to show the poke also.
As promised.
Front 20x9+35mm 235x35
Rear 20x10+40mm 275x30
As promised.
As promised.
No it will not work too much offsetThis will probably seem like a dumb question but, has anyone tried bolting their rear Wheels (255 x 19") onto the front, will they fit ??
Looking for a cheap easy way of replacing the front 225 x 19"
Not a dumb question, but it will not work. Using this link Wheel Offset Calculator You can enter tire sizes and offsets to compare how the offset impacts the clearance to the suspension components.This will probably seem like a dumb question but, has anyone tried bolting their rear Wheels (255 x 19") onto the front, will they fit ??
Just ordered a set of 19x9.5 Niche Misano M116 +35 wheels in Gunmetal. They will be wrapped in 255/35R19 Firehawk Indy 500s
I'm an AWD GT2 at stock ride height and will be adding F&R Eibach sways and ATQ collars as well.
Should be an entirely different machine![]()
I picked up my rims and tires today. Does not look like the 19x9.5 Niche Misano wheels will work on their own at a +35 offset.
Things spin but I can't get the thickness of cereal box cardboard between the rim and the strut.
Am heading back to the tire shop tomorrow to see what my options are. Likely 5mm spacers on the front. I had originally requested +30 but they didn't come in that offset. Damn...
Could you provide some closeups? I am not understanding what you described. Never heard of two valve stem holes!?Note: These rims have 2 valve stem holes, one in the front for the tire valve stem and one in the back for TPMS sensors. If you use the back hole for the TPMS it will require the use of a no-show type of sensor that does NOT have a valve stem on it.
That looks really good, nice choices.I finally got my rims and tires yesterday.
I wanted a square setup for my AWD
255/35R19 Firehawk Indy 500 tires
I used hubcentric rings on the rear - 67.1mm ID to 72.6mm OD
I used 5mm thick hubcentric spacers on the front - 67.1mm ID
The rings would not fit on the front with the spacer in place.
Stock Springs & struts, Eibach F&R sways, ATQ collars
View attachment 25561 View attachment 25560
View attachment 25558 View attachment 25559
Any link for lug nuts and HCR.I recently purchased some Ark Performance 225S from Nick. He was less expensive than the K8Stinger store. I had Discount Tire (DT) mount them for me.
On my drive home I had vibration I had never experienced before, so a couple days later I had DT check them out. They told me I should get some Hub Centric Rings.
Stupid me. I assumed that because HCR and new lugs were included in the set from K8 that the set through Nick would also. They didn't....
So, I bought some aluminum HCR and some racing lugs, put them on, and all is well.
As an aside, on the cost side, it ended up costing me more in total than if I had ordered from K8.
A mediocre suggestion...Amazon has a ton, though they're often in sets of three sizes which may or may not be useful.Anyone got any good suggestions for a thin walled socket for Aftermarket wheels?
You should be ok but I would go with 35 since they are 19. I have 255/35/20 and 285/30/20.I can’t decide to go with the 285/30 or 285/35 in the rear. The difference is 0.3” inch smaller in diameter or 1” inch larger in diameter. Stock suspension.
