@Terry, I am not sure if you have read this thread,
How to launch on boost
by removing the pedal sensor connector I was able to launch the car with boost and do a proper burnout. This was just to test what happens if the ECU was not aware if the brake pedal sensor was disconnected. There are two wires in the ECU that are related to the brake (attached diagram) I am pretty confident its wire number 83 that will do the trick. Would it be possible to route that wire to the JB4 so that we can control turning it on/off from the phone app whenever needed, you can add a safety feature Ex. after certain speed it will turn back on, or after a certain amount of time like 30second incase somebody forgets to re-activate it etc.
