Kinvara8017
Updated top post with better instructions! Enjoy! Curious to see if this works for everyone.
That is a significant difference; impressive thank you.Unfortunately it wont let me post images or links to them.. I have 5 time slips from the strip, 2 of which were on LC, the other 3 were from when I got ballsy enough to try the parking brake launch.. my best 60ft was a 1.85 and I'm positive I can shave another .03-.05 off with better throttle control.. my best with LC was 1.98. So it's still not a huge jump but at least it's a start
Updated top post with better instructions! Enjoy! Curious to see if this works for everyone. (step 5 should say to release parking brake, not gas pedal.. wont let me edit more as im too new?)
[[side note, RWD will spin tires while launching with this method]]
20 grams of protein is not enough. Try pouring in two bottles next time!!
Seems like a great dragy launch method but I don't see how you stage if the car moves at all. Makes sense since the brake pedal switch isn't activated, and the results are impressive! Maybe in can drop my 1.83 60 down to 1.70 for an 11.6!@Tonkabob this may be your ticket to mid 11s!
I mean, if you're going to go through any trouble to mechanically change anything you might as well just wire in a brake switch bypass toggle which will basically do the same thing as this but not require using the parking brake.Im still trying to figure out what makes the car hold itself instead of rolling a bit before a hold.. Sometimes it will just stick without the couple feet roll and other times it has to inch a bit.. Anybody know if its possible to tighten up the parking brake?
Dont let a little moisture stop you from a good timeThis doesnt sound plausible. Not sure I'm buying this. Raining here or I'd try it.
We need someone with a JB4 to try this and log the boost at launch.
Can you confirm the exact steps I wrote above?
It works. Also raining here, but my tires spun wayyyy faster from a stop compared to if I were to use launch control. I think it would be extremely hard to stage at the track though, unless we can find a way to make the car 'full stop' on command.This doesnt sound plausible. Not sure I'm buying this. Raining here or I'd try it.
Follow it up with an alkaseltzer.20 grams of protein is not enough. Try pouring in two bottles next time!!
Why do you say that? It's not like this is comparable to a neutral slam... I don't see how this would be any worse than launch control as the trans is still being loadedI would not recommend this to anyone, Angel if you try it make sure to video tape.
