Kinvara8017
So its my first post on here and I figured i would make it a good one! Recently, at the 1/8mi drag strip, i found it possible to launch my GT2 AWD on a couple pounds of boost with a couple of these steps: stock tires on 25psi all around on cheap track prep asphault , Sports mode, TC/SC off, Pull up about 10ft behind the line, hold the parking brake switch up and lightly give it gas. it should roll a couple feet before truly stopping. Now hold the parking brake switch up still and give it almost half throttle of gas, I can audibly hear my turbos sucking in air and my car will launch at around 2600-2700 if timed correctly though the nanny will kick in if you hold it for too long.. I was able to hit a 7.88 1/8mi while doing this with just a muffler cut, race chip GTS on setting 6 out of 7 (cant hit 7 as it will overboost and put car in nanny), agency power intakes, and an agency power BOV kit.. anxious to see what it can run with this on a flash tune with a couple more parts... do what you will with this info!!
1. Sports mode
2. Hold down Traction button till a beep is heard
3. Pull up on electronic parking brake and hold it
4. Slowly press the gas pedal till you start hearing the turbo spool and hit 2500-2700rpm
(your car might roll a little, let off the gas before the turbo spools and try from step 4 again, dont let off the parking brake)
5. Let go of electronic parking brake once you hit the 2700rpm mark and shift as you see fit..
[[side note, RWD will spin tires while launching with this method]]
1. Sports mode
