brancky3
1000 Posts Club!
Every one of your posts is simply "I'll let the logs speak for themselves" but you don't seem to understand that hundreds of people are reading your post with no idea what timing is or what it does. Without you explaining why these points are bad, you're basically gaslighting and coming off to be an idiot.
Running the turbos hard at high RPM can cause stress and unnecessary heat which isn't evident in any case since I doubt anyone has over 30k right now. I don't expect to see any numbers for EGT or any other relevant data point, but it's been noted in other car communities that holding boost up high is not good (with small turbos / outside efficiency range).
The same cannot be said about timing, the map will be specific to this car to most extents. If the ECU is not pulling timing back, why is it bad? JB4 is not intercepting / hiding the signal from the ECU.
On the other side, we have people running Lap3 saying that the 21psi they're running is no big deal (although they've been really quiet lately for some reason).
