The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
you need to buy it like 26bucksAfter getting the jb4 do I need to buy the iOS app or does it come with a download key in the box? I don’t wanna buy it now then find that in the box.
Thanks
Thanks
broke down again jb4 connected, I dunno on to map 5 fingers crossedView attachment 12716
Ok guys I got the chip installed and put in the fuel setting I saw. The car was boosting funny. After I hit the button flat boost its working great now. Do these setting look correct? And how do I know the fuel wires aren’t working? This is new to me so any tips to get started would be great. I put it on map 5 by mistake did not go full throttle but I have to watch my fingers.you dont have to input any changes for maps 1 and 2. You should probably play around with those two maps first. Only on map 3 do you need to change fuel bias only. But that requires blended fuel e85 and high test.Now that I look at it I think I have the wrong setting in there. I’ll put the setting in at the start of this thread.
Thanks, is there anyway to know if the fuel wires are working?you dont have to input any changes for maps 1 and 2. You should probably play around with those two maps first. Only on map 3 do you need to change fuel bias only. But that requires blended fuel e85 and high test.
View attachment 12725 Ok guys I got the chip installed and put in the fuel setting I saw. The car was boosting funny. After I hit the button flat boost its working great now. Do these setting look correct? And how do I know the fuel wires aren’t working? This is new to me so any tips to get started would be great. I put it on map 5 by mistake did not go full throttle but I have to watch my fingers.
Flatboost is for setting map6 boost values quickly. Fuel setting should match defaults in thread: Kia & Hyundai JB4 - N54Tech.com - International Turbo Racing Discussion
If you need tuning help then just record a JB4 log of what you want us to look at/help you with.
Sound good, it felt like the boost wasn’t not coming on smooth car was running fine though. Is it possible the car was still to cold and the safely measured made it do that? For the safety measures for knock are they on from default or do I have to turn them on. Thanks againNothing you should be able to really feel. Without a JB4 log it's not possible to offer any useful advice. So if it acts up again be sure to record a log.
Thanks, it was weird the first drive I did boost was coming on really odd. But after a couple min it seemed to go back to normal. Drove it twice now and it’s been running fine. Does the jb4 do some learning at first or something?
Guys took plugs out with out removing intake made a small video with comments.
So I’ve had a issue twice now while using the low boost mode tune 4. It gone to 0% boost the turbos are making zero boost. Then I change to tune 0 and it’s still zero boost. After turning car off and on then I get normal boost. Is this just a issue with that mode 4? Here is a screen shot when I have no boost. I wonder if I have a defective tuner.
