SSR Performance down pipes sound
Does anybody else car constantly burple/pop when coasting? It's most apparently in Sport mode due to the lower gear usage and engine braking effect. I am 100% stock exhaust, other then these SSR pipes. When the engine is cold, I get some hellaciously loud pops.
I do a lot of stop and go traffic, honestly it can get old after 45 minutes.
Only in Sport mode and typically after i've been accelerating rapidly from light to light. I wouldn't call them "hellaciously" loud though. I like the burble sound.
That is what my Borla does when let off the gas when slowing down but mine is not very loud but I do here popping here and there lol
My factory cat back must have a hole in it!
It certainly sounds much louder, and louder than I would expect. However, I've had my car on the track (circuit, not drag) quite a few times. I'm sure the muffler material has been "broken" in.
Non stop 40-140 stints back to back definitely heat things up
That makes sense.
Mine has definitely gotten louder too as I barely noticed a sound difference when I installed the pipes but after a few thousand kms the exhaust note and the burbles are louder and more apparent.
I’m quite happy with how it sounds now.
That makes sense.
The exhaust note was very quiet when I first purchased it. After the break in I hit the track for 2 days straight. Since then I've done a handful of track events in the Advanced Group. Pretty much full throttle everywhere except corners!
The note has certainly changed, and I'm wondering if the muffler material on mine has been heated/broken in differently than others.
I will run my Stinger on the circuit track called (area 27 ) , on the 27 th of June and most likely just following a Pace car in a novice group lol This perhaps the only chance I will get to do it , as it is very expensive but it will be a good experience:) this will really break in my exhaust system:)
