RUFFSTUFF
Harbor Freight here I come!
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Used the tips from the video and this thread to knock it out quickly, thanks guys! Below was my setup.
1. 5/8" x 6" Magnetic Swivel Socket - https://www.amazon.com/gp/product/B01MZ25YJU
2. 3/8" Drive Universal Joint - https://www.amazon.com/Craftsman-Universal-Joint-Drive/dp/B00GWBLLQ8
3. 3/8" x 6" Extension - https://www.amazon.com/TEKTON-14208-8-Inch-6-Inch-Extension/dp/B000NY6RD2/
4. 3/8" Drive Wrench & 3" Extension - Pickup locally at a hardware store, could probably pickup #2 & #3 there as well.
5. 10mm 60-degree offset wrench (not pictured) - https://www.amazon.com/Performance-Tool-W80620-Offset-Bleeder/dp/B000N35LKI/
The offset wrench was incredibly helpful for getting the coil packs off. Note that the purpose of the 6" extension and the 3" extension is so you can remove one as needed depending on what you're doing or you'll be too high and hitting the hood.
Maybe I'm wrong, but I would think that a similar 1/4" setup might allow slightly greater flexibility and slightly more room than a 3/8" setup?Used the tips from the video and this thread to knock it out quickly, thanks guys! Below was my setup.
I had problems with the driver side bolts as well. I never was able to get the middle one back in - it just refused to bite. What did you replace them with?
Hey guys what did you torque the plugs to and did you adjust the gap of your new plugs? I heard new plugs should be gapped to 0.26 is this what you guys have done?
Picked up a (7) pack of M6x1.00 20mm bolts from AutoZone. The are slightly shorter than the OEM but they worked perfectly and like I said, <$5.
Worked like a champ! I used class 10.9 yellow zinc coated (Fastenal part # 0128749) and it threaded in instantly.
If anyone is unclear, like I was. This is how the coil packs come apart. Once you understand that, it makes the whole process of that plug under the intake much easier to deal with.
Yep. My 13-year old proved to be extremely helpful...my hands were hopeless. Many thanks to @DiabloStinger and others for the good info. Can't wait for the JB4 (on order) to arrive. Now to order some good octane booster real quick - any recommendations? No E85 nearby, best I'm seeing is 92 octane at the local pumps.FYI if anyone manages to lose any coil bolts like I did, the part # is 1141706256K
This is where I ran into trouble. Going to have to wait until I can enlist the help of someone with smaller hands because there's no way I'm removing that connector with my fat clumsy mitts.
I think I was pushing and pulling a bit too hard.Mine came out fairly easily in one piece...
Happens on everyone’s first time...I think I was pushing and pulling a bit too hard....
